 Post subject: Seagate Barracude 7200.10 ST380215A
PostPosted: December 16th, 2013, 7:32
I'm unable to communicate wit ST380215A via terminal
TX upper second pin right to left
RX lower second pin right to left
ground first pin right to left
baudrate 9600
FW: 3.AAC
 Post subject: Re: Seagate Barracude 7200.10 ST380215A
PostPosted: December 16th, 2013, 20:51
I think the baud should be 38,400
PostPosted: December 17th, 2013, 3:33
RX/TX signals on Seagate hard drives:
http://atola.com/products/insight/manua ... ction.html
3. Open up the terminal window, select the port number and speed (for Seagate 7200.10 and older: 9600; for 7200.11 and newer: 38400);
PostPosted: December 17th, 2013, 3:52
The "[10]24k" would suggest that the baud rate is correct. Other than verifying the parity and start/stop bit settings, I would measure the voltage levels on both sides of the TTL interface. I would also confirm the grounding.
PostPosted: December 17th, 2013, 4:13
Yes, and the "Mas" is the start of the "Master" output from a healthy drive of this type.
PostPosted: December 17th, 2013, 5:24
Problem SOLVED. It was problem with grounding, like Mr. Zabkar mentioned.
I connect ground directly to HDD.
HaQue, thank you for your baud rate suggestion. For this model is 9600
Thank you Mr. Zabkar, HaQue and PCImage for your replays and support
PostPosted: December 17th, 2013, 5:26
ground on HDD chasis/screw
PostPosted: December 17th, 2013, 11:07
glad you got it sorted. Thanks fzabkar
Users browsing this forum: Google [Bot] and 37 guests
