 Post subject: WD1600AAJS-60B4A0 - PC3K desn't recognize the drive
PostPosted: December 18th, 2013, 20:08
Hi Gurus,
I got the following drive:
WD1600AAJS-60B4A0
At first I tried to get ID identification of the drive (by PC3K WD utility) but without success.
I thought that it was due to week heads (the drive respond very slowly). So, I ordered the right donor and made the heads swap.
Now the drive immediately get into ready state but without any ID identification. The drive keep spinning.
Any suggestions?
Here is the SA structure test report:
(I uplpoad the report as a TXT file too)
Id : Importance: ABA :Size:Read : Hdr : CS : CS Value: Vers. : Desription
0001: B : 0: 24:Yes : Ok : Ok : 004C :00020000:Modules directory
0035: Dd : 24: 10:Yes : Ok : Ok : 004C :1008-F15:SA Defects
006D: : 5617: 1:Yes : Ok : Ok : 004C :00010000:
0110: B :104311: 24:Yes : Ok : Ok : 004C :00020000:Modules directory (base part)
0102: Dd :104310: 1:Yes : Ok : Ok : 004C :00X10002:Heads map module image
0103: Dd :104308: 2:Yes : Ok : Ok : 004C :DX.0033 :ROM adaptives SA images
0104: Dd :104307: 1:Yes : Ok : Ok : 004C :00010000:Microprogram version image
0105: Dd :104305: 2:Yes : Ok : Ok : 004C :00160000:ROM translator SA images
0107: Dd :104304: 1:Yes : Ok : Ok : 004C :00020000:ROM module image
0106: Dd :104303: 1:Yes : Ok : Ok : 004C :000500AR:ROM module image
0108: Dr : 38: 32:Yes : Ok : Ok : 004C :000500AR:IBI packet
0002: B :104371: 3:Yes : Ok : Ok : 004C :00080000:Configuration (HDD ID)
0017: B :104374: 63:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
001B: B :104437: 117:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
001C: B :104554: 48:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0014: B :104602: 27:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0015: B :104629: 16:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
001E: B :104645: 22:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
002F: B :104667: 6:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
002A: B :104673: 6:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0021: B :104679: 68:Yes : Ok : Ok : 004C :00810007:S.M.A.R.T.
0022: B :104747: 68:Yes : Ok : Ok : 004C :00810007:S.M.A.R.T.
0023: B :104815: 68:No : : : : :S.M.A.R.T. Log (reserved)
0024: B :104883: 68:No : : : : :S.M.A.R.T. Log (reserved)
0013: B :104951: 55:No : : : : :Loaded part of microprogram code
0080: B :105006: 12:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0011: B :105018: 411:No : : : : :Loaded part of microprogram code
0019: B :105429: 31:No : : : : :Loaded part of microprogram code
0012: B :105460: 53:No : : : : :Loaded part of microprogram code
0050: As :105513: 3:No : : : : :Parameters table 1
0051: As :105516: 3:No : : : : :Parameters table 2
0052: As :105519: 3:No : : : : :Parameters table 3
0053: As :105522: 3:No : : : : :Parameters table 4
0109: Dd : 70: 385:Yes : Ok : Ok : 004C :00010000:ROM image
0061: B :105910: 29:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0062: :105939: 1:Yes : Ok : Ok : 004C :00010000:
001F: B :105940: 20:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
006E: B :105960: 2:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
006F: Dr :105962: 612:No : : : : :
0115: :106600: 162:No : : : : :
0116: : 5780: 6:Yes : Ok : Ok : 004C :000500AR:
0118: : 5786: 20:Yes : Ok : Ok : 004C :000500AR:
AC55: :106762: 1:No : : : : :
4002: :106763: 1:Yes : Ok : Ok : 004C :000500AR:
0121: : 96110:8193:Yes : Ok : Ok : 004C :NOT_INIT:
1101: : 5668: 16:Yes : Ok : Ok : 004C :NOT_INIT:
0033: Dd : 455:1423:Yes : Ok : Ok : 004C :00150000:P-List (Primary defect list)
0031: Ad : 1878: 924:Yes : Ok : Ok : 004C :00250000:Translator
000C: B : 2802: 5:Yes : Ok : Ok : 004C :00010100:Models table
0034: C : 2807: 23:Yes : Ok : Ok : 004C :00150000:G-List (Grown defect list)
0032: B : 2830: 32:Yes : Ok : Ok : 004C :00170000:Relo-List (Candidate defects)
0036: Ad : 2862: 9:Yes : Ok : Ok : 004C :00010000:T-List Module
0029: B : 2871: 6:Yes : Ok : Ok : 004C :00010000:Loaded part of microprogram code
0040: As : 2877: 125:Yes : Ok : Ok : 004C :00010000:Adaptive data
0041: As : 3002: 125:Yes : Ok : Ok : 004C :00010000:Adaptive data
0042: As : 3127: 125:Yes : Ok : Ok : 004C :00010000:Adaptive data
0043: As : 3252: 125:Yes : Ok : Ok : 004C :00010000:Adaptive data
004E: B : 3377: 46:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0049: As : 3423: 3:Yes : Ok : Ok : 004C :00010000:Adaptive data
004A: As : 3426: 26:Yes : Ok : Ok : 004C :00010000:Adaptive data
004D: As : 3452: 1:Yes : Ok : Ok : 004C :00010000:Adaptive data
0003: As : 3453: 27:Yes : Ok : Ok : 004C :00020000:Format Select Data Module
0004: B : 3480: 393:Yes : Ok : Ok : 004C :00020000:Family models configuration (Main)
0025: : 3873: 257:Yes : Ok : Ok : 004C :000500AR:
0026: : 4130: 129:Yes : Ok : Ok : 004C :000500AR:
0038: B : 4259: 257:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0039: B : 4516: 17:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
0037: Dr : 4533: 1:Yes : Ok : Ok : 004C :00010000:Gain Call Data Module
002D: Dr : 4534: 308:Yes : Ok : Ok : 004C :00020004:Debug Log
002E: B : 4842: 308:Yes : Ok : Ok : 004C :00020004:Loaded part of microprogram code
0068: : 5150: 68:Yes : Ok : Ok : 004C :00810007:
0069: : 5218: 68:Yes : Ok : Ok : 004C :00810007:
006A: : 5286: 68:Yes : Ok : Ok : 004C :00810007:
00B5: Dr : 5354: 160:Yes : Ok : Ok : 004C :000500AR:WRRO Log Module
006B: B : 5514: 4:Yes : Ok : Ok : 004C :000500AR:Loaded part of microprogram code
003A: : 5518: 3:Yes : Ok : Ok : 004C :00000100:
0028: Dr : 5521: 16:Yes : Ok : Ok : 004C :00030000:Factory Self Test script
003B: : 5537: 16:Yes : Ok : Ok : 004C :00030000:
003C: : 5553: 16:Yes : Ok : Ok : 004C :00030000:
003D: : 5569: 16:Yes : Ok : Ok : 004C :00030000:
003E: : 5585: 16:Yes : Ok : Ok : 004C :00030000:
003F: : 5601: 16:Yes : Ok : Ok : 004C :00030000:
0119: : 5806: 5:Yes : Ok : Ok : 004C :0100....:
00DE: Dr : 5816: 194:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00B6: Dr : 6010: 179:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D5: Dr : 6189: 173:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3411: : 6362: 104:Yes : Ok : Ok : 004C :1008-F15:
00D1: : 6466: 213:Yes : Ok : Ok : 004C :1008-F15:
00DA: Dr : 6679: 205:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00DB: Dr : 6884: 183:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00DF: Dr : 7067: 209:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00DD: Dr : 7276: 176:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D6: Dr : 7452: 179:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3402: : 7631: 186:Yes : Ok : Ok : 004C :1008-F15:
00D7: Dr : 7817: 180:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D2: Dr : 7997: 119:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3300: : 8116: 122:Yes : Ok : Ok : 004C :1008-F15:
3301: : 8238: 114:Yes : Ok : Ok : 004C :1008-F15:
00BB: Dr : 8352: 137:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3405: : 8489: 143:Yes : Ok : Ok : 004C :1008-F15:
00D9: Dr : 8632: 113:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D4: Dr : 8745: 117:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00DC: Dr : 8862: 125:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D0: Dr : 8987: 122:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D3: Dr : 9109: 103:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00F7: : 9212: 174:Yes : Ok : Ok : 004C :1008-F15:
00BA: Dr : 9386: 148:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3406: : 9534: 139:Yes : Ok : Ok : 004C :1008-F15:
00B9: Dr : 9673: 144:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00BC: Dr : 9817: 139:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00D8: Dr : 9956: 107:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00BD: : 10063: 210:Yes : Ok : Ok : 004C :1008-F15:
00BE: Dr : 10273: 27:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
3401: : 10300: 137:Yes : Ok : Ok : 004C :1008-F15:
3302: : 10437: 121:Yes : Ok : Ok : 004C :1008-F15:
00B8: Dr : 10558: 2:Yes : Ok : Ok : 004C :1008-F15:Single Plug Test Communication Module
00BF: Dr : 10560: 8:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00E6: Dr : 10568: 64:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test log
00E7: Dr : 10632: 32:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test parameters module
00B7: Dr : 5618: 18:Yes : Ok : Ok : 004C :NOT_INIT:Test Clamp Data
00FA: Dr :105525: 256:No : : : : :Butterfly Log
00FC: Dr : 34: 4:Yes : Ok : Ok : 004C :NOT_INIT:Factory Self Test module
00FD: Dr : 11071: 64:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00EE: Dr :104335: 5:Yes : Ok : Ok : 004C :1008-F15:RRO Data Log
3E00: :106574: 5:No : : : : :
3801: : 10664: 32:Yes : Ok : Ok : 004C :1008-F15:
3C00: : 5636: 32:Yes : Ok : Ok : 004C :NOT_INIT:
3415: : 10696: 375:Yes : Ok : Ok : 004C :1008-F15:
00C4: Dr : 11138: 226:Yes : Ok : Ok : 004C :DX.0033 :Calibrations module
00A8: : 11364: 159:Yes : Ok : Ok : 004C :DX.0033 :
00A2: : 11523: 226:Yes : Ok : Ok : 004C :DX.0033 :
00C5: Dr : 11749: 76:Yes : Ok : Ok : 004C :DX.AF07 :Calibration script (DCM)
00C3: : 95458: 191:Yes : Ok : Ok : 004C :DX.0033 :
00C8: : 95649: 227:Yes : Ok : Ok : 004C :DX.0033 :
0091: Dr : 95876: 4:Yes : Ok : Ok : 004C :DX.0033 :Calibrations module
00CC: Dr :106588: 12:No : : : : :Calibrations module
00CA: Dr :105898: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0099: :105886: 12:Yes : Ok : Ok : 004C :NOT_INIT:
0098: :105862: 24:Yes : Ok : Ok : 004C :NOT_INIT:
00CB: Dr :105850: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CD: Dr :105838: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CF: Dr :105826: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CE: Dr :105814: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0093: Dr :105802: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C1: Dr :106587: 1:No : : : : :Calibrations module
00C2: Dr : 95880: 2:Yes : Ok : Ok : 004C :DX.0033 :Calibrations module
00C7: Dr :106586: 1:No : : : : :Calibrations module
009E: Dr :106581: 5:No : : : : :Calibrations module
00C6: : 94710: 55:Yes : Ok : Ok : 004C :NOT_INIT:
00C9: : 94646: 64:Yes : Ok : Ok : 004C :NOT_INIT:
0094: :105792: 10:Yes : Ok : Ok : 004C :NOT_INIT:
0096: : 94526: 120:Yes : Ok : Ok : 004C :NOT_INIT:
0097: :104347: 24:Yes : Ok : Ok : 004C :NOT_INIT:
00AA: : 95882: 124:Yes : Ok : Ok : 004C :DX.0033 :
00A9: : 94466: 60:Yes : Ok : Ok : 004C :NOT_INIT:
00A5: : 94451: 15:Yes : Ok : Ok : 004C :NOT_INIT:
00A6: : 94091: 360:Yes : Ok : Ok : 004C :NOT_INIT:
0092: Dr : 94041: 50:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00A0: : 93977: 64:Yes : Ok : Ok : 004C :NOT_INIT:
00A1: : 11825: 104:Yes : Ok : Ok : 004C :DX.0033 :
009A: : 93937: 40:Yes : Ok : Ok : 004C :NOT_INIT:
009C: :106580: 1:No : : : : :
2000: : 92337:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2001: : 90737:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2002: : 89137:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2003: : 87537:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2004: : 85937:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2005: : 84337:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2006: : 82737:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2007: : 81137:1600:Yes : Ok : Ok : 004C :NOT_INIT:
2020: : 81057: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2021: : 80977: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2022: : 80897: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2023: : 80817: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2024: : 80737: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2025: : 80657: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2026: : 80577: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2027: : 80497: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2030: : 79897: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2031: : 79297: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2032: : 78697: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2033: : 78097: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2034: : 77497: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2035: : 76897: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2036: : 76297: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2037: : 75697: 600:Yes : Ok : Ok : 004C :NOT_INIT:
2010: : 75537: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2011: : 75377: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2012: : 75217: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2013: : 75057: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2014: : 74897: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2015: : 74737: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2016: : 74577: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2017: : 74417: 160:Yes : Ok : Ok : 004C :NOT_INIT:
2040: : 74067: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2041: : 73717: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2042: : 73367: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2043: : 73017: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2044: : 72667: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2045: : 72317: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2046: : 71967: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2047: : 71617: 350:Yes : Ok : Ok : 004C :NOT_INIT:
2050: : 71567: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2051: : 71517: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2052: : 71467: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2053: : 71417: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2054: : 71367: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2055: : 71317: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2056: : 71267: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2057: : 71217: 50:Yes : Ok : Ok : 004C :NOT_INIT:
2060: : 70817: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2061: : 70417: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2062: : 70017: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2063: : 69617: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2064: : 69217: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2065: : 68817: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2066: : 68417: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2067: : 68017: 400:Yes : Ok : Ok : 004C :NOT_INIT:
8010: Dr : 67106: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802C: Dr : 67111: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8035: Dr : 67114: 16:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8038: Dr : 67130: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803C: Dr : 67132: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8016: Dr : 67134: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
801D: Dr : 67139: 33:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8044: Dr : 67172: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8031: Dr : 67174: 4:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8062: : 67178: 13:Yes : Ok : Ok : 004C :6302....:
8063: : 67191: 13:Yes : Ok : Ok : 004C :6302....:
8041: Dr : 67204: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8042: Dr : 67206: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800E: Dr : 67208: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802D: Dr : 67213: 33:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8019: Dr : 67246: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802F: Dr : 67251: 4:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8034: Dr : 67255: 33:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802E: Dr : 67288: 4:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8032: Dr : 67292: 4:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8017: Dr : 67296: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8002: Dr : 67301: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800B: Dr : 67303: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8005: Dr : 67305: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8020: Dr : 67307: 4:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8046: Dr : 67311: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8045: Dr : 67313: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8027: Dr : 67315: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8014: Dr : 67317: 1:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
801C: Dr : 67318: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8023: Dr : 67320: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
801F: Dr : 67323: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803A: Dr : 67325: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803E: Dr : 67327: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8012: Dr : 67329: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8026: Dr : 67334: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802B: Dr : 67347: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8029: Dr : 67352: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
802A: Dr : 67354: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8037: Dr : 67356: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803B: Dr : 67358: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800F: Dr : 67360: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800A: Dr : 67365: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8025: Dr : 67367: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8009: Dr : 67369: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800C: Dr : 67371: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8006: Dr : 67373: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8018: Dr : 67375: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
800D: Dr : 67377: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8008: Dr : 67382: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8024: Dr : 67384: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8015: Dr : 67386: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8007: Dr : 67388: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8065: : 67390: 33:Yes : Ok : Ok : 004C :6302....:
801A: Dr : 67423: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8030: Dr : 67428: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
801E: Dr : 67430: 49:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8001: Dr : 67479: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8022: Dr : 67481: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8064: : 67486: 5:Yes : Ok : Ok : 004C :6302....:
8049: Dr : 67491: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
805D: : 67504: 5:Yes : Ok : Ok : 004C :6302....:
805E: : 67509: 13:Yes : Ok : Ok : 004C :6302....:
805F: : 67522: 16:Yes : Ok : Ok : 004C :6302....:
8060: : 67538: 2:Yes : Ok : Ok : 004C :6302....:
8061: : 67540: 2:Yes : Ok : Ok : 004C :6302....:
8011: Dr : 67542: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803F: Dr : 67547: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8040: Dr : 67549: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8033: Dr : 67551: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8043: Dr : 67564: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8000: Dr : 67566: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8021: Dr : 67568: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8FFC: : 67571: 1:Yes : Ok : Ok : 004C :6302....:
8FFD: : 67572: 8:Yes : Ok : Ok : 004C :6302....:
8FFE: : 67580: 16:Yes : Ok : Ok : 004C :6302....:
8047: Dr : 67596: 33:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8048: Dr : 67629: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8004: Dr : 67642: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8003: Dr : 67645: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8028: Dr : 67648: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8039: Dr : 67651: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
803D: Dr : 67653: 2:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8036: Dr : 67655: 16:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
801B: Dr : 67671: 33:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8013: Dr : 67704: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804C: Dr : 67709: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804D: Dr : 67714: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804E: Dr : 67727: 100:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804F: Dr : 67827: 3:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804A: Dr : 67830: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
804B: Dr : 67835: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8050: Dr : 67848: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8051: Dr : 67853: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8052: Dr : 67866: 16:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8053: Dr : 67882: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8054: Dr : 67887: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8055: Dr : 67900: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8056: Dr : 67905: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8057: Dr : 67918: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8058: Dr : 67923: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
8059: Dr : 67936: 5:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
805A: Dr : 67941: 13:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
805B: Dr : 67954: 16:Yes : Ok : Ok : 004C :6302....:Single Plug Test Log Module
805C: : 67970: 2:Yes : Ok : Ok : 004C :6302....:
8066: : 67972: 2:Yes : Ok : Ok : 004C :6302....:
8067: : 67974: 5:Yes : Ok : Ok : 004C :6302....:
8068: : 67979: 13:Yes : Ok : Ok : 004C :6302....:
8069: : 67992: 15:Yes : Ok : Ok : 004C :6302....:
806A: : 68007: 3:Yes : Ok : Ok : 004C :6302....:
806B: : 68010: 3:Yes : Ok : Ok : 004C :6302....:
806C: : 68013: 4:Yes : Ok : Ok : 004C :6302....:
1000: : 94768: 15:Yes : Ok : Ok : 004C :00000001:
00B1: : 94783: 17:Yes : Ok : Ok : 004C :00000001:
00B2: : 94800: 22:Yes : Ok : Ok : 004C :00000001:
1001: : 94822: 15:Yes : Ok : Ok : 004C :00000001:
1002: : 94837: 18:Yes : Ok : Ok : 004C :00000001:
1009: : 94855: 22:Yes : Ok : Ok : 004C :00000001:
1003: : 94877: 20:Yes : Ok : Ok : 004C :00000001:
1005: : 94897: 14:Yes : Ok : Ok : 004C :00000001:
1004: : 94911: 17:Yes : Ok : Ok : 004C :00000001:
1007: : 94928: 14:Yes : Ok : Ok : 004C :00000001:
1008: : 94942: 25:Yes : Ok : Ok : 004C :00000001:
1100: : 5684: 16:Yes : Ok : Ok : 004C :NOT_INIT:
1110: : 96006: 16:Yes : Ok : Ok : 004C :NOT_INIT:
1102: : 11929: 16:Yes : Ok : Ok : 004C :NOT_INIT:
00E0: Dr : 11945:2500:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test defects log
00FE: Dr : 14445: 650:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
00FB: Dr : 94967: 250:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test module
120F: : 5700: 17:Yes : Ok : Ok : 004C :NOT_INIT:
00E8: Dr : 15095: 736:Yes : Ok : Ok : 004C :1008-F15:Factory Self Test head 0 defects log
1213: : 96022: 16:Yes : Ok : Ok : 004C :NOT_INIT:
Zone allocation table
HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
MODULES DIRECTORY (01)
Location State
ABA:0 Size:24 Ok
Modules number.......................... : 350
CONFIGURATION MODULE (02)
Location State
ABA:104371 Size:3 Ok
HDD Identify
Model................................... : WDC WD1600AAJS-60B4A0
Serial number........................... : WD-WCAT23709114.....
Logical parameters...................... : LBA : 312 581 807
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
Location State
ABA:11749 Size:76 Ok
PINNACLE
+--- Head DCM Codes -------- Media DCM Codes -----+
| WDB: 7 | SHOWA: F |
| SAE: D | KOMAG: K |
Relo-List (32)
Location State
ABA:2830 Size:32 Ok
Defects number.......................... : 0
P-List (33)
Location State
ABA:455 Size:1423 Ok
Defects number.......................... : 786
G-List (34)
Location State
ABA:2807 Size:23 Ok
Many Thanks for any help! :)
SA structure test.txt [41.36 KiB]
Downloaded 394 times
 Post subject: Re: WD1600AAJS-60B4A0 - PC3K desn't recognize the drive
PostPosted: December 18th, 2013, 20:24
Looks like an obvious FW issue we see quite often on B3A0 and B4A0.
PostPosted: December 18th, 2013, 20:43
I thought so but didn't want to corrupt your opinion.
By the way I tested the patient heads on the donor drive and indeed they are gone.
Any suggestions to deal with that FW issue?
PostPosted: December 19th, 2013, 3:56
Mod 11 (overlay) is bad. Very common issue.
You need a compatible module to re-write it.
But quite often the SA surface belonging to that module is damaged, so then the fun starts! :-)
PostPosted: December 19th, 2013, 5:11
If the SA surface is damaged, then find a good free section of the SA, write a copy of your module there, and then edit MOD 01 to point to the new location. You will need to recalculate the checksum for MOD 01 after doing this.
PostPosted: December 19th, 2013, 6:55
That's correct.
Also make sure you have a full back of ALL tracks and mods before you try re-locating mod11, just in case something goes wrong :-)
PostPosted: December 27th, 2013, 1:57
How do I recalculate the checksum for MOD 01?
PostPosted: December 27th, 2013, 3:43
The 4 checksum bytes are located at offsets 0xC - 0xF.
The checksum bytes need to be chosen so that the sum of the MOD's little-endian 32bit double words is 0x00000000.
Here is a free checksum calculator:
http://malthus.zapto.org/viewtopic.php?f=22&t=80&p=93
PostPosted: December 27th, 2013, 5:21
Easily accomplished in PC3K.
