WD5000AAKB 500GB IDE won't spin
December 26th, 2013, 16:41
This HDD was used in a Rosewill external enclosure. I stopped using it a long time ago. I've decided to retrieve data from it. It is now attached to an ICY DOCK MB981U3N-1SA SATA & IDE Adapter. It simply won't spin. What are my options?
Re: WD5000AAKB 500GB IDE won't spin
December 26th, 2013, 17:22
Can you measure +5V and +12V at the drive's Molex power connector?
EZ-Adapter MB981U3N-1SA USB 3.0 2.5”/3.5” SATA & IDE HDD Adapter:
http://www.icydock.com/goods.php?id=156
December 26th, 2013, 17:52
How would I do that? I'm a bit of a novice. Although I do have experience with fixing the nightmare that was the Seagate 7200.11.
December 26th, 2013, 18:15
A digital multimeter should cost you less than US$10, even as low as $3.
December 26th, 2013, 19:17
I'll see about getting a digital multimeter tomorrow. I hope I can get further instructions afterwards. I did apply power to it and it did not spin.
December 27th, 2013, 23:20
It's late but I have the multimeter. How do I test for +5V and +12V at the drive's Molex power connector?
