 Post subject: Western digital head swap question
PostPosted: December 18th, 2013, 14:49
Hello forum..
Yesterday my most important hard disk drive fell off my hands on the floor and my heart stopped for a few seconds :)
When i put it back on-line i heard clicking noise from the heads. I open it carefully and I saw that one head has broken.
The hard disk is a Western digital
MDL : WD3200KS-00PFB0
LBA 625142448
DCM HHBACAJAH
So decided to swap heads watching some videos on you tube and reading some articles, but i need to find the compatible heads.
So my question is :
Do you know for sure what letters from DCM should be the same to find the same heads ?
Thank you very match.
Kostas
File comment: My hard disk
 Post subject: Re: Western digital head swap question
PostPosted: December 18th, 2013, 15:47
The DCM is the least of your issues, these drives have hideous inter-head alignment issues which prove very tricky, even for a lot of pros.
So with respect, I give you 0.1% chance of succeeding :-(
If you need the data then send it to a DECENT pro, with specific experience with this model.
PostPosted: December 18th, 2013, 16:58
i will take my chances.. :)
But can you answer to my question ? what about the DCM letters ?
PostPosted: December 18th, 2013, 17:18
There is conflicting information about DCM and what characters are necessary to match. Some people say 4&5 and some say 5&6
But to me personally, DCM is mostly irrelevant and have had success with using heads from drives with totally different DCM, and even model.
But in 99.9% of cases the drive DOES NOT spin up and work right off on its own, as you're expecting it to. I can virtually guarantee that.
Sorry it's not what you wanted to hear :-(
PostPosted: December 18th, 2013, 17:28
Positions 5 & 6 for this model.
This is a drive with 6 heads, and a lid / bearing cap alignment issue. You've already buggered up the head alignment by opening the drive. The fact that this drive doesn't have a parking ramp, but parks heads on the platters, and one head is broken, means that there is media damage.
You'd be better off spending your time and money with a bottle of Tsipuro, vrai.
Yiassou (kai kali tehee),
Yiannis
http://www.datasaversllc.com
PostPosted: December 18th, 2013, 17:58
ok guys.. i think you are right but i will try to do it. 0.1% is enough for me :)
Yasoo Yanni!!!
PostPosted: December 18th, 2013, 18:08
What do you think about this ?
mine is HHBACAJAH
new is DSCACAJCA
4,5 & 6 are the same.
do you think its combatible ?
http://www.ebay.com/itm/Western-Digital ... 20dbd638c7
PostPosted: December 18th, 2013, 20:21
an advice : don't try to swap head
A professionel wil recover a big part of the data with the preserved heads ( he can control each head and image data with each one ).
PostPosted: December 18th, 2013, 20:22
That's pretty good match or even closer:
http://www.ebay.com/itm/Western-Digital ... 2ecb811599
or
http://www.ebay.com/itm/Western-Digital ... 53feb9f93d
PostPosted: December 19th, 2013, 3:57
Too late, he's already replaced them once :-(
PostPosted: December 19th, 2013, 10:30
Please post the outcome for all to see the result of DIY "Headswap after watching some videos on it". I think it will be a valuable piece of data for anyone else contemplating it.
PostPosted: December 19th, 2013, 10:46
First of all thank you for your intrest and your answers to my problem.
I didnt replace them yet, i just open it and saw that one of the heads is broken.
is anyone here tried to swap heads like me and succeeded ?
if the heads are combatible and put them carefully to the platter without touch the heads each other and park them on the platter next to the ring like the old ones, do i have to do something else ?
PostPosted: December 19th, 2013, 11:27
Then I must ask HOW did you see that it was broken? Is it the top platters head or other?
Bosse
http://www.rescue-it.se
PostPosted: December 19th, 2013, 11:28
Sorry, I didn't read your first message properly.
I just saw "So decided to swap heads watching some videos on you tube and reading some articles," and assumed incorrectly you'd already done it!
Still won't change my advice though...
DON'T!!!!!!!!!
PostPosted: December 19th, 2013, 15:47
Bosse
No its one head inside the platers. I did take out the heads carefully to see the damaged head.
PostPosted: December 19th, 2013, 18:57
Did you say RING... There should be no rings on the platters. It should be crystal clear... If there is a ring, then you have a big problem.
Shane
PostPosted: December 19th, 2013, 20:48
Shane
i ment the center of the platter, the ring that has some screws
PostPosted: December 19th, 2013, 20:58
I feel like nick Cage in "Knowing"
PostPosted: December 20th, 2013, 14:12
:lol:
PostPosted: December 21st, 2013, 9:17
Did you open it in a clean room ?
Users browsing this forum: No registered users and 90 guests
