 Post subject: WD5000BMVW-11AMCS0 MOTOR NOT SPIN UP
PostPosted: December 24th, 2013, 11:49
hello friends
the a/m drive is not spinning at all. we looked into this site in order to find the right procedure to find the best way to make drive spinning. we have a donor drive. we already opened the drive and saw clearly -- no move of platters
not succeded
can anyone help?
tks a lot ephraim
 Post subject: Re: WD5000BMVW-11AMCS0 MOTOR NOT SPIN UP
PostPosted: December 24th, 2013, 13:09
OH, you did the bad ... You have trouble on Leg and you made heart surgery!
Why didn't you check PCB first?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: December 24th, 2013, 23:14
sorry. i checked the pcb. looks ok
PostPosted: December 26th, 2013, 9:44
hi
just not spining at all. yes we tried move the spindle by hand. not moving at all.
yes we opened the drive in clean room. looks the motor is stucked
tks a lot splidit
PostPosted: December 26th, 2013, 18:58
Might be jammed inside our something leaning on the platters. Are you sure its not a stuck head preventing the disk from spinning?
If the motor is jammed then I believe there is a tool that you screw onto the spindle motor and force it free.
PostPosted: December 27th, 2013, 1:20
tks ShaneWard
can u be more specific about the tool.
i was searching a lot without success
brgds
ephraim
PostPosted: December 27th, 2013, 5:52
The tool Shane is talking about is actually for desktop drives. If your drive truly has a seized motor then you need to replace the motor. I suggest outsourcing as I feel your next question is going to be how to replace a motor.
PostPosted: December 27th, 2013, 6:04
tks thatdellguy
you are right, this is going to be my next question. i am surprize there so little info about that
waiting for answers
brgds
ephraim
PostPosted: December 27th, 2013, 13:56
Well, you have to swap platters and unload & reload the heads.
There is plenty of bad video info on the web how to do this yourself in the privacy and comfort of your kitchen. Prepare to lose your data without knowledge, tools, and practice.
In other words, this is NOT recommended.
http://www.datasaversllc.com
PostPosted: December 28th, 2013, 12:05
jono-ats
tks a lot
ephraim
Users browsing this forum: Majestic-12 [Bot] and 174 guests
