 Post subject: HOT SWAP ON SAMSUNG HDD
PostPosted: January 4th, 2014, 12:29
well, for hot swap to access SA, same spec hdd is required. Is it applicable to use SAME Series HDD when exact donor is not found?
Example:
Native HDD: HD082GJ, PCB: BF41-00163A
DONOR HDD: HD161HJ, PCB: BF41-00163A
BOTH HDD from same series, but different model and different in size.
So, is it possible to gain SA access by using this one as donor?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: HOT SWAP ON SAMSUNG HDD
PostPosted: January 4th, 2014, 12:48
NO.
PostPosted: January 4th, 2014, 12:51
BlackST wrote:
NO.
Thanks for confirmation
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 86 guests
