 Post subject: NEED Help WD15EARS
PostPosted: January 7th, 2014, 21:50
Hello everyone I am in need of some help. I had 5 WD green 1.5 TB drives setup in a raid configuration for a backup machine. Anyway the machine got pulled and so did the drives so I have 5 hard drives on my desk. I don't need to recover the data I just want to be able to reuse the drives somewhere else. I have tried to do a LLF with some tools I found on the forums but I get "Format Error occurred at offset : 1117 - Device I/O error" you guys or gals have any suggestions?
 Post subject: Re: NEED Help WD15EARS
PostPosted: January 7th, 2014, 21:55
Use MHDD for basic diagnostic.
PostPosted: January 7th, 2014, 23:13
I used the scan tool and I got a catastrophic failure. the drive shows up I can get the drive info.
PostPosted: January 8th, 2014, 2:58
Worn out. If you want to do some experiment is good but it is likely a waste of time especially on this kind of drives. Need to find someone in your area or near that have the gear and know how to refurbish them for a nominal fee, and recertify them. I am too far, sorry.
P.s. it is not always possible to fix this kind of situation, or the outcome is partial, i.e. a good 300 GB instead of a broken 500 , but forget the 500...
PostPosted: January 9th, 2014, 15:58
Yes All the drives are in the same condition. I think I am going to just cut my losses Thanks guys
Users browsing this forum: No registered users and 49 guests
