 Post subject: Hello all.
PostPosted: January 11th, 2014, 20:21
I am having a problem with a HDD. I just pulled it from a barely used ps3 actually. And I put it in my HP 2000 Notebook. I tried installing a fresh copy of Win7 x64 Ultimate. I got a couple BSOD errors. First was a 0x0000050 error. This happened directly after the Install option on the disc. I was not able to get to the Format part before that. So I put in a Ubuntu disc and used Gparted. When I opened Gparted it had the red! next to the Drive saying Unallocted space. So I just created a new ntfs partition and that took care of the red! . I then restarted laptop with Win7 disc again and worked no problems up until about 52% of installing the OS. I then get a new BSOD error with 0x00000024. I restarted and this time deleted the partition using the win7 disc instead of just format. That worked and made it all the way to the install. (I am using my other laptop now for this).
Now, I installed Crystal Disc. No problems and it's listed Good.
I installed HDTune prop 5.5 and it says (B8)End to End Error Detected. 98 98 99 2 failed.
Also (c7) Interface CRC Error Count 200 200 0 1 attention
I am currently running the full scan and so far it has no damaged blocks about 50% through.
I have not done chkdsk yet as I am waiting for .NET framework to install so I can then install seatools and try that. But .NET seems to be taking it's sweet old time to download so it's just a wait game before I can run these last 2 tests.
Any idea about the 2 error listed above from HDTune? I will of course update once I get the final two tests done. The HDD was barely used AT ALL.
Now that I've had the actual Win7 install I have already installed quite a few programs such as the ones listed above and also things like firefox, ccleaner , malwarebytes etc and have not received any BSOD just happened while installing.
BTW it's a ST9320325AS 320gb
If I forgot anything or you need anymore info just let me know. From what I googled about the End to End is all different responses from negative nothing to worry about to trash it now lol.
 Post subject: Re: Hello all.
PostPosted: January 11th, 2014, 21:36
Update.
Just finished the HD Tune Pro Error scan 100% with no errors or damaged blocks.
Still haven't done chkdsk or seagate so will update ASAP.
Sorry another update, Won't keep posting new to TTT the same thread.
I just restarted the laptop and got yet another BSOD. This time it was 0x000000A IRQL_Not_Less etc? I have never seen this many BSOD before with a fresh install of Windows ever. After the BSOD it gave me the option of startup repair or start normally, I hit start normally and no problems started back up. What the HECK?!
PostPosted: January 12th, 2014, 1:27
Ok one last update for the night. I just turned it on and had every BSOD thrown at me lol. So far the HDD passed all tests though is what I don't understand? Could it have anything to do with coming out of a PS3? Anyways take a look at all the BSOD codes I just received..of course now it's running no problem after about the 10th time.
0x000001d
0x0000050 (Page fault in not Page area..I think is what it said) It did this one a couple times actually
0x000001e
0x000000a (IRQL less not Less or equal blah blah blah)
The only thing I will say about this one though is this time it happened after I tried installing the video driver but the video driver still had a code 37 Windows cannot initialize the driver error under device manager.
So far the HDD passed:
-Basic HDD test in BIOS
- HD Tune Pro test (no bad blocks etc)
- Seatools Short Drive self test and Smart test. I now have it running the Fix all Long test so this should be done by morning.
I am clueless. Passes all tests but yet I keep getting the BSOD. In the morning if it works through this fix all long I will do a chkdsk r and then will try another format and windows install. Unless I get any tips or idea on here.
PostPosted: January 12th, 2014, 3:25
Ok final update on this post tonight i swear lol.
Seatools finished faster than I though. Passed the Fix All Long version no problems. Now running chkdsk /r. Will leave this one on all night but so far is has go through everything no problems. Not sure if I somehow screwed it up with Ubuntu making the new partition which i made it ntfs btw, or if it has some type of firmware messing with it from being inside a ps3? But we'll see. Thanks again.
PostPosted: January 12th, 2014, 3:31
Does the PS3 HDD have any issues such as what hddhacker was used for regarding XBOX drives?
I never played around with Hard disks in consoles but I remember a mate playing with programs to get them to work.
Possibly checkout whats involved in putting a PC Hdd in a PS3 and reverse the process.
PostPosted: January 12th, 2014, 13:01
Thanks for the reply. After a quick search I see the ps3 possibly uses a Fat32 system. So could be onto something here. I am just getting up so I will do a little more research. I though I would have taken care of that problem since I formatted with ubuntu into ntfs but maybe didn't do it correctly?
PostPosted: January 12th, 2014, 14:01
After turning it on for the first time this morning I got a 0x0000003b Blue screen this time. And I noticed one thing in the last couple error codes. They all said it could possibly be a ram problem..so...
I "MIGHT" have found the problem? I just ran memory test through the control panel + restart. It got to about 6% and said problems were detected please contact computer manf. So could this possibly be causing all the BSOD, a ram stick?
I will find out soon enough when I get a chance to either swap the hdd in another laptop and see if I get any of the blue screen or if I can find some ram laying around. I have my fingers crossed as I am not sure a bad ram stick would cause this many darn different blue screen codes.
PostPosted: January 12th, 2014, 15:26
memtest86 or memtest86+ are often recommended for RAM testing.
http://www.memtest86.com/ (memtest86)
http://www.memtest.org/ (memtest86+)
http://en.wikipedia.org/wiki/Memtest86
PostPosted: January 12th, 2014, 22:33
Ok one more update.
So after running the chkdsk /r I eventually did a format then deleted the partitions using my windows disc. I re installed windows with no bsod this time, I now installed all updates. no bsod. Have had it running since about 11am est. No problems at all, it even passed the memory test this time...?? All from just format and deleting the partitions. No clue what happened, maybe it did have some type of firmware on hdd from ps3? Or maybe the chkdsk or seatools fixed it? No issues at all for over 8 hours of constant running...so far.
PostPosted: January 13th, 2014, 4:25
lots of BSOD errors when installing windows can be from having to choose "ide" or "legacy" mode instead of AHCI mode in the BIOS, or installing the F6 drivers for the disk controller.
PostPosted: January 14th, 2014, 11:50
Sorry didn't want to keep bothering with updates. But I am almost positive it is between 1 of 2 things. After these two fixes I haven't had problems in a few days and I tried restarting about 5 times in a row and everything else with no bsod.
1) changed both ram sticks
2) disabled that VT option in my BIOS (A lot of HP laptops has it). Don't remember enabling this in the first place but disabled it a couple days ago and no problems. But it was the same day as switching ram sticks so not sure which did the trick.
Thanks again for the tips.
