 Post subject: Seagate Barracuda 7200.10 is not accepting any commands !
PostPosted: February 16th, 2014, 17:01
I have an empty, working Seagate barracuda 7200.10 connected to a terminal for practice purpose. I have" F>" prompt but the terminal responds as invalide for all commands that I entered. When I try to change the levels using " /1" or other similar commands, the terminal shows error too. I have seen in this site that all discussions about terminals have" F3>" prompt, I do not know why I am getting the "F>". Could someone please give me a little push to the right dircetion.
Thanks.
 Post subject: Re: Seagate Barracuda 7200.10 is not accepting any commands
PostPosted: February 16th, 2014, 17:05
http://malthus.zapto.org/download/file.php?id=443
PostPosted: February 17th, 2014, 14:31
Thank you fzabkar.
Unfortunately for me, the first half of the document is in Russian and in PDF, which I do not understand and which I can not google-translate. Is there an English version of this document ?
PostPosted: February 17th, 2014, 14:50
Are you getting
F>
or
T>
Should be getting T>
If your getting F> it implies you are stuck at the firmware level (which only accepts a few commands eg ? )
and its surprising that the drive works at all (which you say it does)
and try R1 and R2
from the end of viewtopic.php?f=1&t=27679&start=20
PostPosted: February 17th, 2014, 15:05
Thanks xsoliman.
When I connect to Terminal, the first thing that I get is F> not T>
Command R2
gives the following response:
HM HM HM...........Code - FF Track 155c E.0.1AA Sns 1AA
xsoliman wrote:
Are you getting
F>
or
T>
and try R1 and R2
PostPosted: February 17th, 2014, 15:30
If you getting F3 in promt on that drive you're not bad :mrgreen:
http://www.rescue-it.se
