ATTO cards
February 25th, 2014, 3:06
Hello
How can I use ATTO HBA adapters in PIO mode? any suggestion?
https://www.attotech.com/products/family.php?id=1
Re: ATTO cards
February 25th, 2014, 13:44
Which OS?
Re: ATTO cards
February 25th, 2014, 14:14
Use for Victoria on Windows for example
Re: ATTO cards
February 25th, 2014, 15:39
You should be able to disable DMA mode in the Windows registry. I don't know if that works for all HBAs, or if it will give the desired result. That said, I don't know if a PIO option is available for SATA devices, or even if it makes sense, unless the SATA controller is configured for IDE emulation.
Re: ATTO cards
February 25th, 2014, 23:28
Thanks, I will check it
