 Post subject: WD10EADS : need some help please
PostPosted: February 21st, 2014, 6:06
Hi there,
The drive : WD10EADS-11M2B3
At power up, it spins up and get ready.
Heads map............................... : 0,1,2,3
head is 0 weak (not bad, but very slow)
Other heads are ok.
If I try to access data, fall in ABRT error
Is the head too weak for data recovery ?
I don't have donnor PCB yet, what should I match ?
If I have to search for donnor heads, actually I search for 5th and 6th char in DCM. Is it true ? extended model is relevant too (-11M2B3) ? head map ?
because I have a donnor with DCM match (patient DGNNNT2CGB, donnor HHRCNT2MH) and donnor is 6-head, while patient is 4-head
Patient :
WD10EADS-11M2B3
DCM DGNNNT2CGB
Actual donnor
WD10EADS-00P8B0
Head maps unknown (pcb hs) but probably 0,1,2,3,4,5 - can't switch off Unnecessary heads
DCM HHRCNT2MH
Another potential donnor I have
WD10-EADS-00M2B0
DCM HARCHV2MAB
Many thanks for help
 Post subject: Re: WD10EADS : need some help please
PostPosted: February 21st, 2014, 6:29
Banned User
hddr49 wrote:
Hi there,
Other heads are ok.
Patient :
WD10EADS-11M2B3
DCM DGNNNT2CGB
Actual donnor
WD10EADS-00P8B0
DCM HHRCNT2MH
WD10-EADS-00M2B0
DCM HARCHV2MAB
Do you have a PC3000 or Salvation Tool? what is the S.M.A.R.T Report?
PostPosted: February 21st, 2014, 8:17
Yeah, PC3K UDME with DE here
I clear SMART, test running...
PostPosted: February 21st, 2014, 10:42
There are three option which helps you but first full backup the firmware.
1: Solve Slow problem
2: Translator Regeneration
3: Clear smart with Glist
After that used Explorer mode on Data Extractor to recover the Data!
Need more help I will connect via Team Viewer!!
Huge thank you for your help.
Sorry for not aswer your PM, I'm too new and the feature not avalaible for me yet.
Full backup done with copy 1 (copy 0 is too slow - a week not enough)
1 & 2 - already done, no effect
3 : let's do it !
Edit : 3 Done (Erase G-List), no effect
PostPosted: March 6th, 2014, 6:56
Solved.
I found a compatible drive
- WD10EADS-11M2B3
- DCM HANCNT2MA
- S/N & DATE CLOSE ENOUGH
I switch heads, and I currently recover data.
Users browsing this forum: Bing [Bot], Google [Bot] and 219 guests
