 Post subject: Looking for suggestions on recovering an encrypted drive
PostPosted: March 6th, 2014, 13:21
Greetings! Looking for some advice on next steps for getting data off of a dead drive.
In 2006 I had a Windows xp machine with it's own ide Bootable drive. I had a 2nd IDE drive (a Seagate barracuda) attached via an inexpensive usb enclosure. The drive/enclosure was used as a network drive on my windows machine. The drive died unexpectedly one day. No clicking, no warning, just dead. I was not at a point financially where I could afford a data restoration so I just put the drive to the side.
Fast forward to last year, I decided to get the restore done and I send it in to a company. After taking a LONG time to evaluate the drive, they asked for me to send in the old enclosure (which I still had) so I was hoping that was the key but apparently it wasn't. They claimed that the drive had an electronic issue and that the drive was fully encrypted and therefore could not get to the data. They sent me back the dead drive and an ISO image of the drive that cost me $500. They sent me a gif of the mbr and I saw an "invalid partition" error. (The snapshot is attached)
My confusion lies here: While it had been years since I used that pc and drive combination, I don't ever recall encrypting the entire drive. On the off chance that I did, I would hardly know even what program was used to perform such encryption. Moreover, I have no idea how to even possibly decrypt an iso file. My first instinct is to send the drive to another restoration shop but before I do I wanted to get more informed.
1) is it even possible for me to possibly decrypt this iso file myself and if so what tool could I use?
2) is there any value in sending the drive to another shop?
3) is it possible the drive was already encrypted at purchase time? (probably not but I'm really grasping at straws) encrypting an entire drive is nearly a day long operation today, much less 8 years ago and while I don't have an elephant's memory, I think I'd remember spending a whole day not being able to use my drive while saying to myself "just think, if I forget this password I'll never be able to use this drive again! "
Any kind words of advice would be helpful, even if they are "sorry mate but you're fucked". I'm just a bit floored that what I thought was going to be an easy restoration turned into a mess. Thanks for your time!
 Post subject: Re: Looking for suggestions on recovering an encrypted drive
PostPosted: March 6th, 2014, 14:13
First of all the screenshot you attached shows perfectly normal MBR, there is nothing wrong with it. It shows that your drive has 4 partitions (all 4 are most likely NTFS partitions)
Second, based on that screenshot it is impossible to say if your drive has any encryption at all
PostPosted: March 6th, 2014, 14:53
Thanks Doomer - with that in mind, are you aware of a tool that can examine/mount these partitions from an ISO file?
PostPosted: March 6th, 2014, 15:37
R-Studio can
PostPosted: March 6th, 2014, 15:45
Both 7-Zip and IsoBuster can extract files from ISOs.
PostPosted: March 6th, 2014, 18:03
You probably referring to CDFS ISO 9660 file (regular Windows compatible ISO)
I don't think that's a regular ISO file, it seems to be a drive image
PostPosted: March 6th, 2014, 18:08
Yes you are right this is a drive image
PostPosted: March 6th, 2014, 18:10
7-Zip and WinImage can extract files from disc images.
PostPosted: March 6th, 2014, 18:40
why not re-image a similar drive and work with it directly?
PostPosted: March 6th, 2014, 18:42
HaQue - not sure what you mean by re-image a similar drive - please enlighten me
PostPosted: March 6th, 2014, 18:44
I cannot find that 7-zip supports NTFS file system
Do you know that 7-zip supports it?
PostPosted: March 6th, 2014, 19:59
http://www.7-zip.org/history.txt
9.04 beta 2009-05-30
- 7-Zip now can unpack NTFS, FAT, VHD and MBR archives.
Here are several test images:
http://dftt.sourceforge.net/
I have verified that 7-Zip ver 9.20 extracts the files from the following NTFS image (I'm booting from a FAT32 volume):
http://dftt.sourceforge.net/test3/index.html
PostPosted: March 6th, 2014, 20:08
You said you have a drive image, can you get a drive of same size and write the image to it. Though you might not gain anything except not having to fing image-freindly software
PostPosted: March 6th, 2014, 23:33
hi Stozin
just to throw another program in the pot:
http://findandmount.com/ util : small, free and thorough.
K
Голод не тётка!
PostPosted: March 7th, 2014, 6:46
As one can see, the boot sector is not encrypted. This means that there is no hardware encryption, and the drive is not fully encrypted. If there is any encryption, it must be an operating system induced one or software encryption. You might have to remember if you have activated NTFS encryption using Windows explorer.
PostPosted: March 7th, 2014, 11:20
All,
First and foremost, I wanted to say thank you to all of you that responded. Just getting the links for software and insight on the MBR and partitions has been eye opening and whether this ends in success or not, I truly appreciate your efforts.
Here's an update - I spent a brief hour installing R-Studio demo and running simple scans . It recognized three NTFS partitions and one teeny tiny one. R-Studio was unable to recover a few small files that were under 64kb (the limit of the demo) but that may have been because it was a simple scan? Not sure. Tonight I will spend a few hours scanning and getting results. I hope that it can at least grab some image files I haven't seen in ages.
Question - if the partitions were encrypted using EFS or NTFS windows based encryption, would I be able to see files & directories inside those partitions?
PostPosted: March 7th, 2014, 11:52
stozin wrote:
All,
Yes, EFS encryption is file based, so you should be able to see at least file names, dates and sizes
PostPosted: March 8th, 2014, 15:10
Update:
I spent time using both R-Studio and Ultimate Restorer (looks like they are the same engine/software) and while the programs were able to scan the partitions, the data that it found was very minimal at best. Most folders & files come up as "?" and those that don't, when I attempt to restore them, generate logs such as "closing attribute parse allocated size differ from stored one." I haven't been able to restore not even the smallest of files. Is this a demonstration of encrypted data, or is it just fucked?
PostPosted: March 8th, 2014, 22:19
I would examine your image with a disc editor (eg DMDE freeware) in readonly mode. Start by uploading sector 0. Then we can see for certain what kind of file you have. You could also use HxD, depending on your version of Windows.
DMDE (DM Disk Editor and Data Recovery Software):
http://dmde.com/
HxD - Freeware Hex Editor and Disk Editor:
http://mh-nexus.de/en/hxd/
BTW, here is a standard Windows XP MBR:
http://thestarman.pcministry.com/asm/mb ... br.htm#CHS
PostPosted: March 12th, 2014, 17:39
Spildit wrote:
Most likely you are dealing with file base encryption, and that explains why you can see the partition and the file names but they apear as if they don't have any valid content.
Also if you took the drive to a reputable data recovery lab (not an ordinary computer shop) and if they stated the files were encrypted, let's assume for now that their statment is correct.
Maybe you can extract some files from the image and post them here, so we can try to check the file content to confirm encryption ?
Regards.
Thanks for that offer - I should be able to post some files later tonight and we'll see
