 Post subject: t9500424as BSY
PostPosted: March 23rd, 2013, 5:33
Good morning ;
i have a st9500424as
reporting BSY
terminal log is
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380342
the drive was NOT dropped and was being used normally when hanged and not detected anymore .
and it's not clicking
thank you for your ideas
 Post subject: Re: t9500424as BSY
PostPosted: March 23rd, 2013, 5:49
raven4d wrote:
Good morning ;
reporting BSY
terminal log is
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
Hi Dear Friend Raven4d
Firmware Info Plz
PostPosted: March 23rd, 2013, 6:03
jignesh wrote:
raven4d wrote:
Good morning ;
reporting BSY
terminal log is
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
Firmware Info Plz
thank you for your reply
FW:0001BSM1
PostPosted: March 23rd, 2013, 11:58
raven4d wrote:
jignesh wrote:
raven4d wrote:
Good morning ;
reporting BSY
terminal log is
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
Firmware Info Plz
FW:0001BSM1
Dear friend raven4d
Wich Platform U Have Like PC-3000 UDMA Or SalvationData Or Other ?
Tell Me So I Will Give You Some Tips And Advice And Ya Brother Post Your
PCB Pictur Front And Backside Both So I Will Check And Advice If U Have Any Good Platform.
PostPosted: March 23rd, 2013, 16:16
thank you for your idea ..
connecting only the pcb will give the same results !!!
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380338
so , it's not bad heads i think , will try to find a similar drive if not a donor to test with .
thank you again
PostPosted: March 23rd, 2013, 17:15
Spildit wrote:
Do you have external eeprom programer ? Maybe you can dump the ROM on the PCB (if it have one) using an external programmer to check if it's ok or not ...
yes , it does has an external eeprom , will try to dump it's content tomorrow's morning ..
thank you
PostPosted: March 10th, 2014, 6:00
Hello Similar problem to what "reven4d" has been facing
My Model is ST9500423AS Fw: 0003HPM1
Drive spins up initializes properly but remains BUSY
Tried to get terminal access with but could get it only for fraction of seconds then it gives LED CC Error
[quoteEarlySpinup Enabled
Rst 0x10M
ASCII Diag mode
F3 T>
LED:00000067 FAddr:00384F74
][/quote]
Only PCB attains ready state but no TERMINAL Access / Terminal lock.
Any suggestions ???
 Post subject: Re: t9500424as BSY No TERMINAL Access
PostPosted: March 13th, 2014, 2:20
Rst 0x10M
ASCII Diag mode
F3 T>
][/quote]
Any suggestions ???
Users browsing this forum: No registered users and 75 guests
