 Post subject: Toshiba - Heads Issue?
PostPosted: May 29th, 2014, 14:29
Have a Toshiba 1TB laptop drive, model is MQ01ABD100H, and I believe it's bad heads, but would like a second opinion.
In DDI the drive goes ready and IDs properly, but the heads map is all abort errors. Imaging provides nothing but bad sectors.
After DDI, took a look at the drive in Toshiba HD Doctor. Drive ID properly and was able to read in all the FW, but not able to access any of the data.
I don't think I've seen a drive ID properly while having bad heads, but that seems like what it is. Your opinion?
 Post subject: Re: Toshiba - Heads Issue?
PostPosted: May 29th, 2014, 14:37
Did you repower the drive after doing the head map on DDI?
PostPosted: May 29th, 2014, 14:51
Yes, did a repower of the drive, same results. Did a restart of DDI, same results. Even tried a different destination, same results.
PostPosted: May 30th, 2014, 15:12
It would be quick to rule out the PCB with a donor, I'd do that first. I guess you don't have DE to read from active utility?
Data Recovery Cape Town
PostPosted: May 30th, 2014, 15:32
:idea:
PostPosted: May 30th, 2014, 16:56
most of the FW is on PCB, if am not wrong...
Data Recovery Pakistan
PostPosted: June 1st, 2014, 14:18
Correct.
PostPosted: August 19th, 2016, 11:28
Hey FinalKnight: Was this drive ever recovered?
If so, please tell us the steps.
Thanks!
-DP
Users browsing this forum: Google [Bot], napalm_atx and 81 guests
