 Post subject: 4x WD20EARS 1x Dead PCB - Repair Options?
PostPosted: March 17th, 2014, 1:35
I have 4x 2Tb WD20EARS, one of which is producing a clicking pattern, 4 clicks, pause, 1 click, 4 clicks, pause, 1 click, spin down
I have tried the other three PCBs on that drive and all work.
I have tried the suspect PCB on the other 3 drives, same clicking pattern.
So I am guessing, the PCB is in need of.. something
Is there a way of identifying the pattern as a diagnostic acoustic? Google results have come up with this forum but nothing specific.
Any applications for MAC OS I can use which will recognise the drive through a USB caddy connection and perform diagnostics?
If this is a quick and simple swap PCB at low cost, could anyone recommend a good supplier for international postage?
Many thank for any assistance.
 Post subject: Re: 4x WD20EARS 1x Dead PCB - Repair Options?
PostPosted: March 17th, 2014, 3:18
You already have your answer I think.
Are you saying that the 3 other PCB's you tried that "all work" gave access to DATA properly as well? without any type of ROM transfer.
If so, by another PCB and jobs done.
PostPosted: March 18th, 2014, 5:51
Thanks, that is pretty much what I suspected.
Any good resellers for WD PCBs in the UAE?
Users browsing this forum: Google [Bot] and 32 guests
