 Post subject: Samsung HD321KJ T166(S)
PostPosted: March 18th, 2014, 19:53
Hi this drive failed-in-place. It does not ID in PC3000 and shows .49MB for size.
(I get the 2 Green lights correctly, but BSY appears after a few minutes.)
Drive spins and no scratchy or clicking sounds. There is NO Terminal output
whatsoever.
Just opened and closed it in the clean-room - it's pristine inside.
Could I get a nudge, please? I am thinking swapping controllers....
-Oy
 Post subject: Re: Samsung HD321KJ T166(S)
PostPosted: March 19th, 2014, 3:17
Firmware issue I would expect, nothing to do with PCB.
PostPosted: March 19th, 2014, 11:50
I must have an old copy of the PC3000 manual.
Does anyone know if there is a newer manual that works with
any of the "HDxxx" models of Samsung drives?
Or, is what's written pertinent?
All I get in Terminal screen is in Red letters:
"Techno mode error: unexpected error: drive is not ready
Utility initialization was terminate!"
-Oy
PostPosted: March 19th, 2014, 13:08
Maby a silly Q, but have you tried hotswap?
http://www.rescue-it.se
PostPosted: March 19th, 2014, 19:58
Thanks, I have a Donor on it's way and I'll report results here.
-OY
PostPosted: March 20th, 2014, 3:38
You have pc3000 UDMA?
PostPosted: March 21st, 2014, 14:00
Yes I have 2 of them.
Oy
PostPosted: March 21st, 2014, 16:37
Ok.
I would try as mr-spokk suggested and try a hot swap.
Use HS to backup the fw on the patient and then clear A-list and smart.
Users browsing this forum: Google [Bot] and 33 guests
