 Post subject: WD1200BEVS Not accessible
PostPosted: November 27th, 2008, 12:50
I have a WD1200BEVS-00UST0 which reaches ready and has capacity of 0. When entering PC3000 utlity I get the following error:
Techno mode key
Techno mode key......................... : Ok
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "DISK DAM ERROR"
Head number reading..................... : Ok
Heads number............................ : 2
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
Head Map Reading Error.................. : Head map check sum error
ROM version............................. : 06.19C
ROM generation.......................... : 06.19C
Link table version...................... : 01.2E.
Heads configuration..................... : default
Head map................................ : 0,1
Service area:
SA dir reading.......................... : SA Directory checksum error
Configuration reading................... : Module 02 not found
Any ideas?
 Post subject: Re: WD1200BEVS Not accessible
PostPosted: November 28th, 2008, 4:09
Check for rom corruption. The fact the headmap has checksum error is suspect.
PostPosted: November 28th, 2008, 4:11
P.s. Did you try another pcb and checked ALSO the translator?
PostPosted: March 23rd, 2014, 9:20
Any luck with the error as per solution.
I'm getting the Head Map Reading Error : Head map sum error on WD750BPVT
Regards,
Users browsing this forum: Google [Bot] and 33 guests
