 Post subject: Help me to do .dump and get my password by HMDD
PostPosted: April 13th, 2014, 8:06
ALL experince man I have Hdd locked .. I dont know how to get .dump by HMDD
I tryd one month to get .dump to open my HDD .
when I used MHDD ,, I cant aple to do script or .dump .
MHDD said script file not found .
Pls Help my to unlock my HDD as soon .
 Post subject: Re: Help me to do .dump and get my password by HMDD
PostPosted: April 13th, 2014, 8:08
My email is rataj3zafaran@hotmail.com
PostPosted: April 13th, 2014, 8:10
I used this methood below :
Prepare this tools
1. 1.44 Floppy drive
2. MHDD Version 4.5 in floppy image self extract.
(http://hddguru.com/download/software/mh ... floppy.exe)
3. MHDD.zip with script file modified from hddguru .dump
(download/file.php?id=1434)
4. Victoria software, available from Hiren’s Boot CD (http://www.hirensbootcd.org/files/Hiren ... D.15.1.zip)
5. Ultraedit tools (www.ultraedit.com › Downloads)
I have read through all forum publish on internet, mostly from hddguru and spend a couple of days to understand the hex to dec conversion, alt-Gr + Key… but all those thing seems like complicated to me. Luckily I found a blog from (http://elettrofreak.blogspot.com/2011/0 ... -hard.html). I follow the instruction and it work for my case.
In summary, this is the step I did,
1. Download MHDD floppy image self extract and run it to prepare the bootable floppy disk. Luckily I still keep a usb floppy drive and able to find a useable 1.44Mb disk from museum.
2. Go to your floppy drive, there is a folder call MHDD with a file mhdd.zip, you may unzip the file and place it back to the same folder
3. Download MHDD.zip from hddguru, unzip it
4. Copy the scripts folder to your a:\mhdd\scripts folder (you should able to see dump, dump2, dum48 files in the scripts folder)
5. Copy cs.bin from the mhdd.zip to a:\mhdd folder
6. Now boot your system with the hdd locked with the floppy bootable disk
7. You will entering to MS Dos command screen with drive C: ram drive
8. Type this in the dos command prompt
A:
Cd mhdd
Mhdd.exe
9. You will go in to MHDD program
PostPosted: April 13th, 2014, 15:00
any help :|
PostPosted: April 13th, 2014, 17:26
Copy the script file to the same directory as MHDD.
BTW, the script is intended for WD drives only.
PostPosted: April 14th, 2014, 0:21
Dear I have hitachi hdd ,, I can used this script .
PostPosted: April 14th, 2014, 3:28
No, as fzabkar said, it's only for WD.
I don't believe there's a free solution for Hitachi
PostPosted: April 14th, 2014, 5:09
ZU is free, but it doesn't work for all Hitachi models.
PostPosted: April 14th, 2014, 11:42
what is solution for Hitachi
Users browsing this forum: No registered users and 100 guests
