 Post subject: WD10TMVW-11ZSMS5 IMAGING FAILES
PostPosted: April 16th, 2014, 13:23
THE HDD GETS CLONED UPTO 42XXXXXXX SECTORS, THEN IT STARTS TO SKIP SEQUENCIALLY A LOT OF SECTORS AROUND IN EVERY 300000+- SECTORS ALL OVER THE SURFACE TILL END.
I have tested all modules.
Error found on mod 0004 & 006F. usually these 2 modules are found corrupt on all ROYL HDD, never faced any problem. Do you think 0004 is issue? if so, direct replacement from donor gonna work?
I did SMART & G-list clear, nothing improved. same condition.
Did translator regeneration, same condition.
ANy thought please?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD10TMVW-11ZSMS5 IMAGING FAILES
PostPosted: April 18th, 2014, 1:20
No one can shed any light?
__________
THANK YOU
SHAHI
PostPosted: April 18th, 2014, 2:23
Try cloning by head (if you have the tools to do it) and see if the unreadable pertain to individual heads.
PostPosted: April 18th, 2014, 4:08
Tried to do by using HEAD. nothing
Tool used DFL-DDP.
42XXXXXXX - 195XXXXXXX (end) sectors having the issue, seems like some FW issue, Translator? Someone stated it should be ZONE, but no idea how to deal if so.
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 38 guests
