 Post subject: help me to unlock hitachi hard disk
PostPosted: April 14th, 2014, 0:31
I used this methood below not working to get scripts ,, MHDD said scripts not found .
Pls help Iam spend one month to unlock hdd ,, Iam not able to unlock .
methood I used
Prepare this tools
1. 1.44 Floppy drive
2. MHDD Version 4.5 in floppy image self extract.
(http://hddguru.com/download/software/mh ... floppy.exe)
3. MHDD.zip with script file modified from hddguru .dump
(download/file.php?id=1434)
4. Victoria software, available from Hiren’s Boot CD (http://www.hirensbootcd.org/files/Hiren ... D.15.1.zip)
5. Ultraedit tools (www.ultraedit.com › Downloads)
I have read through all forum publish on internet, mostly from hddguru and spend a couple of days to understand the hex to dec conversion, alt-Gr + Key… but all those thing seems like complicated to me. Luckily I found a blog from (http://elettrofreak.blogspot.com/2011/0 ... -hard.html). I follow the instruction and it work for my case.
In summary, this is the step I did,
1. Download MHDD floppy image self extract and run it to prepare the bootable floppy disk. Luckily I still keep a usb floppy drive and able to find a useable 1.44Mb disk from museum.
2. Go to your floppy drive, there is a folder call MHDD with a file mhdd.zip, you may unzip the file and place it back to the same folder
3. Download MHDD.zip from hddguru, unzip it
4. Copy the scripts folder to your a:\mhdd\scripts folder (you should able to see dump, dump2, dum48 files in the scripts folder)
5. Copy cs.bin from the mhdd.zip to a:\mhdd folder
6. Now boot your system with the hdd locked with the floppy bootable disk
7. You will entering to MS Dos command screen with drive C: ram drive
8. Type this in the dos command prompt
A:
Cd mhdd
Mhdd.exe
9. You will go in to MHDD program
 Post subject: Re: help me to unlock hitachi hard disk
PostPosted: April 14th, 2014, 1:52
Pls I need help !!
PostPosted: April 14th, 2014, 1:53
:arrow: :arrow: help help help :idea: :idea: :roll:
PostPosted: April 14th, 2014, 1:55
PostPosted: April 14th, 2014, 11:45
help :roll:
PostPosted: April 14th, 2014, 14:11
What do you want to do?
It does help us if you explain what the problem is and what you have done so far.
https://www.mjm.co.uk/
PostPosted: April 14th, 2014, 19:42
http://malthus.zapto.org/viewtopic.php?f=95&t=166
PostPosted: April 14th, 2014, 21:16
rataj3zafaran wrote:
help :roll:
Might be helpful to post the model number so at least we know what your trying to unlock.
PostPosted: April 16th, 2014, 15:34
Thank to all
PostPosted: April 16th, 2014, 15:40
This 22.BIN U can help me to get password .
00000000:55 00 01 00 00 20 00 64 00 00 ba 00 19 01 00 00 U.... .d..º.....
00000010:00 00 00 00 00 01 60 02 12 00 22 00 0a 00 00 00 ......`...".....
00000020:00 00 00 01 01 00 00 01 e0 01 0f 0f 01 02 02 0a ........à.......
00000030:01 02 00 02 02 08 01 00 ff ff 02 03 50 01 1e 64 ........ÿÿ..P..d
00000040:01 11 04 40 0b 02 00 01 00 00 00 00 05 00 00 00 ...@............
00000050:00 00 ff ff 00 00 00 00 12 0a 12 00 00 00 05 00 ..ÿÿ............
00000060:00 00 00 00 1e 00 00 00 00 00 00 00 00 00 4d 00 ..............M.
00000070:29 00 07 00 12 2e 00 00 00 0e 00 00 00 00 05 00 )...............
00000080:01 00 00 00 00 00 00 07 00 01 02 0d 00 01 03 00 ................
00000090:03 01 00 01 00 00 00 00 00 00 00 01 57 44 43 20 ............WDC
000000a0:57 44 32 35 30 30 42 45 56 54 2d 32 32 5a 43 54 WD2500BEVT-22ZCT
000000b0:30 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0
000000c0:20 20 20 20 20 20 20 20 00 01 53 7c 42 7c 4c 7c ..S|B|L|
000000d0:50 5a 4d 53 48 47 43 51 52 44 56 4d 4b 52 55 4a PZMSHGCQRDVMKRUJ
000000e0:00 20 20 20 20 20 20 20 20 20 20 20 20 20 30 38 . 08
000000f0:2d 32 32 2d 32 30 30 38 00 00 00 00 00 00 00 00 -22-2008........
00000100:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ................
00000110:01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000120:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000130:00 00 57 44 43 57 44 43 57 44 43 57 44 43 57 44 ..WDCWDCWDCWDCWD
00000140:43 57 44 43 57 44 43 57 44 43 57 44 43 57 44 43 CWDCWDCWDCWDCWDC
00000150:57 00 08 40 fe ff 00 01 00 00 00 05 00 64 00 14 W..@þÿ.......d..
00000160:20 32 00 00 00 0f 00 01 02 00 00 01 78 00 32 00 2..........x.2.
00000170:20 00 55 ff 00 01 00 00 00 00 00 00 00 00 00 00 .Uÿ............
00000180:00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 58 ..............XX
00000190:58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
000001a0:58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 XXXXXXXXXXXXXXXX
000001b0:58 58 58 58 58 58 58 58 58 58 58 58 58 58 01 01 XXXXXXXXXXXXXX..
000001c0:01 01 01 00 00 00 00 00 00 00 00 00 00 01 ff ff ..............ÿÿ
000001d0:ff ff ff ff ff ff 00 00 00 00 00 00 00 00 80 00 ÿÿÿÿÿÿ........€.
000001e0:00 00 00 00 00 01 02 05 10 27 00 00 88 13 00 00 .........'..ˆ...
000001f0:00 00 d0 07 00 00 88 13 00 00 1e 00 00 00 05 d6 ..Ð...ˆ........Ö
PostPosted: April 16th, 2014, 21:11
Spildit wrote:
Are you trying to unlock a HITACHI hard drive ? Did you get that dump from your WESTERN DIGITAL drive ?
where there is no password :)
Users browsing this forum: Majestic-12 [Bot] and 44 guests
