 Post subject: Seagate st2000dm001 strange noise
PostPosted: May 2nd, 2014, 13:00
Hi Everybody, i was searching the internet and this forum seems to be the best place to find some help :)
my st2000dm001 today decided to start making strange noises "ta ta tata, ta ta tata" and so on, then it simply dies. Windows doesnt see it and also seatools or other tools.
I tried to clean contacts, also on the pcb, but nothing changed.
Thank you to everybody with some suggestions to make it readable, also only for recovery data!
 Post subject: Re: Seagate st2000dm001 strange noise
PostPosted: May 2nd, 2014, 13:04
viewtopic.php?f=16&t=12671
PostPosted: May 2nd, 2014, 13:27
hi, this means i have to send it to a data recovery company? :)
PostPosted: May 2nd, 2014, 13:59
If data is important enough, then highly recommended. Otherwise, proceed with RMA or whatever else, donate it, etc.
PostPosted: May 2nd, 2014, 14:04
what do you think is the problem? what happened from night to morning?
PostPosted: May 2nd, 2014, 14:09
A bad PSU for instance...
ACELab partner
PostPosted: May 2nd, 2014, 14:15
its a seasonic... should be quite good :/
PostPosted: May 2nd, 2014, 14:50
Thank you! it seems really bad :((
