 Post subject: Need loader for WD10TMVW - 11ZSMS5
PostPosted: April 23rd, 2014, 11:35
I'd appreciate someone could share a loader for this WD, FW: 00650006.
Thanks in advance.
 Post subject: Re: Need loader for WD10TMVW - 11ZSMS5
PostPosted: April 23rd, 2014, 11:46
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1372
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 65.09J
>ROM generation.......................... : 65.09J
>Link table version...................... : 05.0M.
>Consolidated ROM version................ : 00650009
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5
>ROM Firmware version.................... : 00650006
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
11.rar [203.63 KiB]
Downloaded 273 times
PostPosted: April 23rd, 2014, 12:23
Ach. Not lucky with that one - it is not uploading as perm overlay. My ROM actually reports the following:
ROM:
ROM version............................. : 65.06J
ROM generation.......................... : 65.06J
Link table version...................... : 05.0L.
Consolidated ROM version................ : 00650006
ROM Modules:
Thank you for your loader, though.
PostPosted: April 23rd, 2014, 13:42
I'll have another look tomorrow.
If you haven't heard from me by lunchtime, then drop me a PM, I will have forgotten!
PostPosted: April 28th, 2014, 4:00
Try this...
>Techno mode key
>RAM:
>ROM:
>ROM Modules:
>ROM Firmware version.................... : 00650004
>Service area:
11.rar [202.24 KiB]
Downloaded 265 times
PostPosted: April 29th, 2014, 12:01
That one made it! :D
Users browsing this forum: Google [Bot] and 50 guests
