 Post subject: How to permanently set ERC (TLER/CCTL) value on ST31000524AS
PostPosted: April 30th, 2014, 0:49
What tool (other than a script) can I use to permanently set the ERC value of a ST31000524AS drive? I can use smartctl to change the values, but once the drive is power-cycled the value returns to the default (disabled).
Thanks folks.
 Post subject: Re: How to permanently set ERC (TLER/CCTL) value on ST310005
PostPosted: April 30th, 2014, 3:22
I suspect that it may be possible to set the ERC timeout values by modifying appropriate Congen parameters.
See viewtopic.php?f=1&t=27413&start=20
You may like to compare the Congen data against those from an enterprise model, eg ES.2.
PostPosted: May 15th, 2014, 4:26
Sorry, bit of a n00b here I guess. From looking at that thread it appears that Congen is nvram or some such on the drive? What tool does one use to modify this?
PostPosted: May 15th, 2014, 5:31
You need an RS232 TTL adapter. Commands are issued to the drive's serial terminal port using a tool such as HyperTerminal or PuTTY.
Users browsing this forum: jimmydata and 45 guests
