 Post subject: Head Map Donor Match Advice Needed
PostPosted: April 30th, 2014, 13:44
I have a 2.5" WD5000BPVT that needs a head swap. The patient drive has this heads map:-
LH PH
0 0
1 1
2 2
I cannot find a matching donor drive.
I can find one with 4 heads and matching micro Jogs
LH PH
0 0
1 1
2 2
3 3
Will this work okay as a donor? All other parameters (DCM etc) match?
 Post subject: Re: Head Map Donor Match Advice Needed
PostPosted: April 30th, 2014, 13:47
You should be ok
PostPosted: April 30th, 2014, 15:13
In that instance it should work.
Data Recovery Cape Town
PostPosted: April 30th, 2014, 15:19
Thanks both. Will let you know how I get on.
PostPosted: May 1st, 2014, 2:27
I had replace 4 heads in place of 3 heads in WD5000BPVT and they worked like charm.
So go ahead they will work.
PostPosted: May 1st, 2014, 12:02
Thanks ROb
Users browsing this forum: No registered users and 69 guests
