 Post subject: Is there a better SOIC Test Clip tan the one shown below ?
PostPosted: May 4th, 2014, 6:50
I bought this test clip shown below. But, I find it a nightmare trying to grasp the little IC on circuit. Is there a more proffessional one that does not require as much hustle ?
Thanks for any information,
 Post subject: Re: Is there a better SOIC Test Clip tan the one shown below
PostPosted: May 4th, 2014, 8:16
it's better to remove the ROM ic from pcb and read or write . some times there is resistor you should remove before connecting this soic clip
the professional one "IMHU" is normal soic 8 that plug to programmer directly
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: May 4th, 2014, 11:44
Spildit wrote:
I did aquire those blue ones and i find it a little bit dificult to grab the SOIC 8 and to manage for the clip to stay in position while reading/writing.
The i aquire this :
http://www.ebay.com/itm/New-SOIC8-SOP8- ... 43c93190b2
Those black ones are way better and stay way firmly on place while using.
Also read here :
http://malthus.zapto.org/viewtopic.php? ... 3402#p3402
Regards.
I confirm it!
I had also blu one which was not good, after i got a black clip which is very good and i'm still using
My firmware database:
Users browsing this forum: Google [Bot] and 59 guests
