 Post subject: clone the unallocated space
PostPosted: June 2nd, 2014, 20:13
Does somebody know how to clone the unallocated space of a ntfs partition?
 Post subject: Re: clone the unallocated space
PostPosted: June 2nd, 2014, 23:10
technically, if it is unallocated, it isnt part of an NTFS partition, else it would be allocated..If I have it right.. do you mean clone the unallocated space on a disk where there also is an NTFS partition?
or do you mean free space inside the NTFS partition that the cloning tool skips.
Could you clone the whole disk and manually remove the partitions, using DMDE for the offset info, leaving the unallocated space
I havent dabbled too much in partitioning at a hex level so I may be off the mark.
PostPosted: June 2nd, 2014, 23:44
Use ddrescue and specify the starting and ending LBAs of the unallocated space.
PostPosted: June 3rd, 2014, 4:15
@ HaQue
well i try to explan better:
i need to clone the unallocated LBA's of a NTFS partition.
so for example: this partition is 500GB, 150GB allocated to files, 350GB unallocated to files.
i want to get a image of 350 GB, of slack space and unallocated space ONLY.
(maybe i shoud have posted into forensic section)
@ fzabkar
didn't see that function in its guide, are u sure about it?
PostPosted: June 3rd, 2014, 4:29
if files are fragmented, this could be hit or miss
Im wondering what the purpose would be for
PostPosted: June 3rd, 2014, 4:45
sure files are fragmented, but there is a map/list of this fragments, so it should be easy for a software to exclude the lbas referring to allocated files.
PostPosted: June 3rd, 2014, 4:47
positivebit wrote:
@ fzabkar
As Haque has explained, the term "unallocated" has a different meaning than the one you intended. Therefore my advice is not applicable and ddrescue cannot do what you want.
PostPosted: June 3rd, 2014, 4:56
@ fzabkar:
yes u right, correct term is free space not unallocated. :lol:
there is a way to clone a existing partition including only the free space and slack space?
PostPosted: June 3rd, 2014, 5:22
I've never heard of anyone wanting to do what you want, but I know that DR tools can search free clusters and the slack space at the end of files. That said, most files don't end on a sector boundary, so how would you handle a partial sector?
PostPosted: June 3rd, 2014, 5:38
you mean this ?
http://blog.priveonlabs.com/sec_blog.ph ... &tb=1&pb=1
we can't deal with partial sector...that's impossible so far i understand.
Could you image the entire drive and then use a wipe utility to zero every file? This should leave the free clusters untouched, but you would need to verify whether the tool overwrites the slack space.
PostPosted: June 3rd, 2014, 8:43
Easy with DeepSpar
1. select all sectors by mft and bitmap
2. invert selection
3. click "restart scan" on the start scan screen
4. wipe unprocessed sectors when project is complete (this clears out the MFT, MBR and Bitmap sectors read to get the original selection)
PostPosted: June 3rd, 2014, 8:54
Thanx will give it a try and report back here.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 111 guests
