 Post subject: HItachi HTS541080G9AT00
PostPosted: July 26th, 2011, 10:48
Hi
Hi have this HD that doesn't spin up.
I have tested the fuses, and they are OK.
So I need a replacement PCB.
My Pacient drive is:
HTS541080G9AT00 Jun-06
MLC: DA1175
PCB:
OA26798 - DA1188A
Donor:
HTS421280H9AT00 Dec-05
MLC: DA1303
PCB:
OA26790 - DA1187B
What I want to know is if the PCB can be compatible for NV-RAM swap.
Has anyone ever tested it like this?
ACELab partner
 Post subject: Re: HItachi HTS541080G9AT00
PostPosted: July 27th, 2011, 11:10
I guess I would give this a try. :)
PostPosted: July 27th, 2011, 11:47
they are quite diferent ..
MLC: DA1175
PCB:
OA26798 - DA1188A
Donor:
MLC: DA1303
PCB:
OA26790 - DA1187B
you can find what to match in SD and ace manuals
remember to swap NVRAM content ;)
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: July 27th, 2011, 11:54
Luca
Dont believe all you read here is strictly true...
PostPosted: July 27th, 2011, 11:59
many times i only match MCU ... but the rule of the first 2 lines of PCB sticker never failed, I may be wrong but this was my experience.
Bye
Luca
PostPosted: July 27th, 2011, 12:50
I'm gonna test it today, and i'll post the feedback.
ACELab partner
PostPosted: July 28th, 2011, 10:37
Hello
Well, here's the feedback about the swap: It doesn't work :(
It doesn't spin either, nor the pacient or the donor....
Put the NVRAM back on their original boards, and the donor works OK.
So, I need to get a Donor PCB....
ACELab partner
PostPosted: May 12th, 2014, 23:34
Banned User
for this PCB swap, just need to match the first line number on the PCB.
has the same number of OA26798 is the donor PCB. When you get this PCB, you need to change the NVRAM(U6 chip)
