 Post subject: WD3200BEVT-60ZCT0 - Cleared P-list and G-list by mistake
PostPosted: May 15th, 2014, 17:11
Hello everyone. I turn to you with much to ask, because by accident, unconscious reflex, cleaned P-list and G-list. And it was so, Drive WD3200BEVT-60ZCT0 2.5" Sata2 5400rpm, pulled from a damaged laptop HP DV9700 (defective GPU) plugged into the computer, the drive nicely detected, all this time it was in the best fine. Did not expect that starts to bug me bury in SA this drive, No but it happened. I used to do this with WDR3.2 (purchased for their own domestic needs of non-commercial or not a pirate downloaded from the internet) and the first I did was cleaned SMART him, it went ok, and the when I wanted to quit, but something struck me to pry, P-list and G-list. Oh and this time I clicked on the option instead of "Edit P-list" and "Edit G-list" clicked "Clear G-list" and re- "Clear P-list" and interestingly even clicked "Clear Soft Error". swear I did it in ignorance, this I did not copy the modules from the disk before the operation.
I know that WDR has the option to restore the P-list. But I admit I have no idea how to use it. I do not want to spoil anything more, and so have a lot of spoiled.
So to sum up:
The drive is visible in BIOS, WDR
Heads good.
Before the operation, everything was just fine.
Question I have someone to help me rebuild WDR P-list and G-list? Please help :(
:arrow: Ps. Most probably think that the drive I want to sell, Well, I warn you that the disk will wykożystany for my purposes it does not go up for sale. And please also do not think that WDR typically bought for the purpose of profit.
:arrow: Ps2. If someone, wants to work with the HDD, the offer from your site teamviewer.
:arrow: My English is how to say, lame and are backed by some with the help of google translator, because i come from Poland.
 Post subject: Re: WD3200BEVT-60ZCT0 - Cleared P-list and G-list by mistak
PostPosted: May 15th, 2014, 17:30
OOOOO Spildit, heh long to tell here, and it's not here yet time and place to attach a moderator that is not about me :) Overall it is good, helping parents at home not too recently and do not have time during the day (science, work).
You know what Spildit, back to the topic, I tried to click the "Rebuild Plist, but it gives me an error 7600 IBI_Error_code_base and go. Know after this incident, I do not want anything longer move, you know there is always a team viewer :)
PostPosted: May 15th, 2014, 17:40
Spildit, I'll wait for you and you set me. You know I can trust you and know that you are where you need to click. And I've now such a trauma that I'm scared to click anything there.
PostPosted: May 15th, 2014, 17:53
Ok, Spildit. It's no problem.
PostPosted: May 16th, 2014, 5:37
Banned User
I also need proper solution for this problem on Victoria all sector show A error ...
Rebuild Plist not work in almost every time.
$50 for the proper solution.
PostPosted: May 16th, 2014, 6:23
As for my case, after the incident, the initial part of the scan is green (scan conducted HDDTune program), while the red sectors appear in the second part of the disk, are scattered about something ala chessboard. I note that before cleaning the P-list and G-list, the scan passed successfully ie this, all sectors were green.
PostPosted: May 16th, 2014, 7:14
I swear As I write in the first post, unknowingly clicked "Clear P-list, clear G-list", instead of clicking the "Edit P-list and G-list Edit" to this as I write clicked yet, "Clear Soft Error". I did not do anything more. The question I have. Is the WD drive still contains a copy of the current modules!? But do not?
Btw. Yes, heads are Ok.
Ok, Spildit frend that's no problem, I think that thanks to you will be rebuilt, P-list, or set to rights the HDD.
PostPosted: May 16th, 2014, 7:54
So glad that this is a copy somewhere. Anything but I could not get to them or did something wrong, in any case, I prefer to have someone experienced (I am thinking of you) he copied, or set it as it should be. And I have a lesson to the area of the HDD to make a copy of the modules.
In this case, as he writes in the first post I did not copy the modules before any fun with HDD.
btw, the current drive is disconnected from the computer to make it more not knock.
PostPosted: May 16th, 2014, 9:09
OK spildit, he probably will not know what to do best. I do not want to as I wrote already more "spoil" the disk.
btw, at the data on the disk, they were permanently set to zero, disk is empty.
PostPosted: May 16th, 2014, 10:32
Ok, that's no problem Spildit.
btw. Easy, no nerves do not want to get something went wrong with the rebuilding Plist.
And once again thank you for everything Spildit :)
PostPosted: May 17th, 2014, 10:12
Spildit buddy, am very happy,
Plist was rebuilt, Succes :)
btw. Now I have a lesson for the future to make a copy of the modules.
PostPosted: May 17th, 2014, 11:12
Thanks Spildit.
If not for this forum it certainly would not have this knowledge. If I have a problem with the drive HDD, it will certainly call on the forum, or in person on skype. Because I know that you can help me because you are more experienced in this industry. Regards and not littering the forum.
Returning to the subject is to write short: HDD is working perfectly.
Topic can be closed.
Users browsing this forum: Google [Bot] and 79 guests
