 Post subject: HELP ME NOT F3 prompt
PostPosted: May 15th, 2014, 6:56
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
 Post subject: Re: HELP ME NOT F3 prompt
PostPosted: May 15th, 2014, 6:57
Model st500dm002 FIRMWARE-KC45
PostPosted: May 15th, 2014, 6:58
That's normal in some drives.
PostPosted: May 15th, 2014, 7:08
any suggestion
PostPosted: May 15th, 2014, 7:56
hard drive not show in bios (Bsy)
PostPosted: May 15th, 2014, 8:11
help me Spildit where is short Read/ Write channel i Need data its very urgent
PostPosted: May 15th, 2014, 8:16
After setting the COM and select the correct baud rate-38400, and ctrl+z, we couldn’t enter the F3 T>
PostPosted: May 15th, 2014, 8:24
try to unscrew pcb and isolate motor contacts with paper
power on and try with ctrl+z to reach F3 T>
and report
PostPosted: May 15th, 2014, 9:23
check this
viewtopic.php?f=1&t=26966&hilit=st500dm002
viewtopic.php?f=1&t=28343&hilit=st500dm002
PostPosted: May 15th, 2014, 10:11
and report
PostPosted: May 15th, 2014, 10:12
Boot 0x10M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF
ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
after the unscrew pcb and isolate motor contacts with paper
PostPosted: May 15th, 2014, 10:14
If data is important, send to a pro who has the right tools and knowledge to safely recover your files. The more time you spend screwing around, the longer it will take for you to get your data back...plus any mistakes you make could make the cost to recover those files more expensive.
Users browsing this forum: Google [Bot] and 68 guests
