 Post subject: Pls Help WD 500GB SATA recognizition problem
PostPosted: May 15th, 2014, 21:12
Hi, I ve got my previous directv hdd which is a WD GreenPower 500GB HDD. It had PUIS enabled which I disabled with HDAT2. Now my only "problem" is that the HDD appears to be be in PATA mode. Though next to the HDD in HDAT2 is says PATA and it has next to it a yellow exclamation mark which down it says in yellow "!ATA_MODE: MWDMA2 [max. UDMA6/ATA133]". I would like to get it into SATA mode, is that possible using HDAT2? I'll attach a photo. Thanks
 Post subject: Re: Pls Help WD 500GB SATA recognizition problem
PostPosted: May 16th, 2014, 5:35
Banned User
Here you can get data recovery guide not a software option guide better if you discuss the actual problem of the drive and data accessing problem.
Users browsing this forum: Google [Bot] and 76 guests
