 Post subject: Credant file encryption - RAW recovery
PostPosted: May 17th, 2014, 11:15
Hello
We have cases, where are on the drive files encrypted with Credant
and the MFT file table is lost.
Would have anybody solution for RAW recovery of encrypted files?
THanks
 Post subject: Re: Credant file encryption - RAW recovery
PostPosted: May 17th, 2014, 12:44
We would pay for help
PostPosted: May 17th, 2014, 17:17
Banned User
decryption information is necessary this is military grade protection. better you get the decryption detail and solve hdd issue.
PostPosted: May 17th, 2014, 17:34
ddd123 wrote:
Hello
THanks
If files are encrypted with Credant, how do you know the MFT is "lost"?
PostPosted: May 17th, 2014, 17:44
it's not whole drive encryption, but only files are encrypted. I think only office files.
PostPosted: May 17th, 2014, 18:22
Banned User
I got success in many last one is from Australia a MAcafee encrypted endpoint drive more powerful then Credant if user lost the decryption detail i only give you hint is to find the key file from encrypted hard drive with R-studio deep scanning... if you got the files i will complete this case for you at $1000... if can't Credant support also not helps you then get the permission from user to drilled the drive and move on. 8)
PostPosted: May 17th, 2014, 18:27
I was not aware Credant offers file encryption based solution. Even so, I still don't understand the relation to the "lost" MFT.
@DataPlanet
If data is encrypted by endpoint, in what form would the "key" actually show up in the scan?
Also, what endpoint version was that?
PostPosted: May 18th, 2014, 6:46
Banned User
No Time for free work and with you not possible.
Spildit wrote:
Ok then ....
If you are THAT good, just decrypt this for me, ok ?
http://malthus.zapto.org/viewtopic.php?f=96&t=72
- Download spildit.zip from the above link.
- To be sure that I will not tamper the results, here it is the hash for the file inside the TrueCrypt container : Sha1 - B8E8D4B8572250FCCA440736AB1CB7C190012215
- Just post the code inside the file.
:D :D :D
Enjoy.
Users browsing this forum: No registered users and 47 guests
