 Post subject: Segate BARRACUDA ST1000DM003 MCMT error
PostPosted: May 26th, 2014, 11:28
The disk is dosent reconize by the machine at all
Model:
BARRACUDA
MODEL: ST1000DM003 1Tb
PN: 9YN162-500
FW: CC48
SN: SD1D4L0NK
The terminal interface show this:
Boot 0x40M
Spin Up
TCC-0021[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0021
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: EXCEPTION: MCMT SEC copy corrupt
MCMainPOR: MCTStateFlags 0000002E  MCStateFlags 000000C1
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
PowerState = IDLE1
APM disabled by SPort
Help please.
 Post subject: Re: Segate BARRACUDA ST1000DM003 MCMT error
PostPosted: May 26th, 2014, 12:40
In this post with a similar problem the solution was shorting the read chanel
viewtopic.php?f=1&t=27513&p=197760#p197760
I not shure what to short
PostPosted: May 26th, 2014, 14:10
here is one picture of the pbc that I google it
where are the test points?
original-100664987-HDD-PCB-Logic-Board-Board-For-ST1000DM003-Tested-Working.jpg [ 82.9 KiB | Viewed 8496 times ]
PostPosted: May 26th, 2014, 17:24
Tip: How to identify the Read Channel test points:
http://malthus.zapto.org/viewtopic.php?f=24&t=123&p=149
PostPosted: May 27th, 2014, 9:05
Yes I read but im not shure if i find the rigth tespoints .
when i short apears servo errors and the disk not spining
PostPosted: May 29th, 2014, 13:03
Here a pictures of the pbc with a better resolution I mark in red where I think are the test points
Are they correct??
PostPosted: May 29th, 2014, 14:50
You need to measure the voltages at each if those 4 pins with the board off the drive. That will distinguish the read and write pairs.
PostPosted: May 30th, 2014, 10:13
The disk without short have terminal access to all comands
but the ATA interface not reconize at all
Then I can't aply the seagate firmware patch
Via terminal there a way to patch firmware?
Users browsing this forum: Google [Bot], mima85, Pi0tR and 40 guests
