seagate backup plus slim 1tb
August 18th, 2016, 14:10
seagate backup plus slim not detecting in windows 7
sometimes it shows as diskdrive in comp management
I opened the casing and removed hard drive and connected to system not detecting in bios and in device manager too
drive specs
St 1000lm024 Fw 2BA30003
Re: seagate backup plus slim 1tb
August 18th, 2016, 16:43
Its a Samsung
Is it making unusual noise ? (Clicking beeping etc.)
Show the terminal log
August 18th, 2016, 17:37
prasadsv wrote:seagate backup plus slim not detecting in windows 7
drive specs
Hello
If the hard drive spinning up motor still no sound the click-click
You use the terminal to repair the firmware
Good luck
August 19th, 2016, 3:36
drive specs
Hello
Good luck
:shock:
August 19th, 2016, 3:37
jermy wrote:Its a Samsung
+1 show terminal
August 19th, 2016, 12:49
Thank you very much For You All
Today I open hdd it heads damaged it needs same model HDD?
