 Post subject: No prompt from Barracuda ST2000DM001
PostPosted: June 1st, 2014, 17:52
Hi, my first post in a hdd forum, and it's a cry for help!
I have this ST2000DM001, 2TB HD with firmware CC4B and the PCB revision is B, this drive stopped being detected by the BIOS... no weird noises, when powered on you can hear the heads moving, the drive spinning, etc... but no sign of life in the PC.
There are tons of tutorials on how to connect the drive via serial port using the terminal, and I did it, but I never get to the desired prompt... in my case I have 2 outcomes :
1) When the drive is shielded in the heads terminals
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame EC00 0000 0000 7640 0008 0000 0000 0000 F274 0000 0000 0000 0000
0000 0000 0000 5088 EB03 4A35 AAB6 C247 BF34 8802 74E6 B58E 25CC 0000 007F 0000
0000 FFE4 0004 0010
ResponseFrame E580 0000 0000 7600 0008 0000 0000 0000 F2AF 0000 0000 0000 0000
0000 FFE5 0004 0000
ResponseFrame E700 0000 0000 75C0 0008 0000 0000 0000 F2EC 0000 0000 0000 0000
0000 FFE5 0004 0000
ResponseFrame E7C0 0000 0000 7640 0008 0000 0000 0000 F274 0000 0000 0000 0000
0000 FFE4 0004 0000
2) When I connect in a normal state (PCB fully attached)
Boot 0x40M
Spin
RECOV Servo Op=0100 Resp=0005
TCC-001F[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001F
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0000BBAC
[RSRS] 00E7
ProcessRWError -Read- at LBA 000000000000BEDB Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000BF00!
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001F
LED:00000047 FAddr:FFFFFFFE
In both cases this goes on for about five minutes, then the RX led stops flashing... However, I left the drive connected to the computer for an hour and tryed again to ctrl z, but nothing...
No matter how fast I spam ctrl z, It never works... I've left it do his bussines without me touching anything, then come back and give it a try and nothing... I've tryed every imaginable combination, and always the same result, the drive is busy and won't listen to me.
Any idea what I might do?
Thanks in advance
 Post subject: Re: No prompt from Barracuda ST2000DM001
PostPosted: June 2nd, 2014, 7:55
If you need data recovery, then send it to a specialist in data recovery.
It's not an easy drive to work with. Even you get terminal access, there will more than likely be other issues with the drive that any common free software out there will fail to produce a successful recovery.
 Post subject: Seagate Barracuda ST2000DM001 data rescue
PostPosted: June 2nd, 2014, 8:00
95% that's defects in the system area / 5% -- bad heads.
First option isn't too hard to work with, second one is more problematic.
PostPosted: June 2nd, 2014, 10:40
Do you have any suggestion of data recovery experts in america? (U.S., Canada)
Users browsing this forum: Google [Bot] and 62 guests
