 Post subject: WD10JMVW-11S5XS1
PostPosted: November 9th, 2013, 10:30
Hello!
The customer give me this drive to retrieve his data. The original problem was slow responding and I converted the drive from USB interface to SATA interface with compatible SATA PCB and fixed the drive. And already recovered his data.
The weird thing that I recovered the data with SATA PCB. There's no encryption :shock:
has any one saw this before?
 Post subject: Re: WD10JMVW-11S5XS1
PostPosted: November 9th, 2013, 12:20
The WD10JMVW (WD Elements) USB-SATA bridge does not include an encryption chip. That's why the data wasn't encrypted.
PostPosted: November 9th, 2013, 15:34
Does it have Inic-3608 USB chip?
PostPosted: November 9th, 2013, 17:48
+1
Type the serial number into WD's warranty checker and you should see a "1TB Elements SE":
http://websupport.wdc.com/warranty/warr ... sttype=end
That said, is it possible that Elements models could use an encryption-capable bridge, but that encryption is not enabled in the firmware?
PostPosted: November 10th, 2013, 5:18
It is not 100% correct. Sometimes it does include but encryption feature swithed off.
For the OP drive, there is possible JMS bridge.
Angel Data Recovery
PostPosted: November 10th, 2013, 8:56
Yes sir.
WDBBEP0010BBK-EESN
1 TB My Passport
PostPosted: November 10th, 2013, 12:12
unknown wrote:
Yes sir.
These are self-encrypting drives
Inic-3608 has an ability to encrypt data but this ability is not used for data encryption. Instead data is encrypted using Marvell chip, and it's encrypted inside the drive, meaning that no matter what the interface is (SATA or USB) user will always see data decrypted.
But because data is encrypted inside, cryptographic erase is supported (among other perks), so when you do "format", using special WD utility, new data key will be generated inside the drive and old data becomes inaccessible.
PostPosted: November 10th, 2013, 12:17
Inic-3608 has an ability to encrypt data but this ability is not used for data encryption. Instead data is encrypted using Marvell chip, and it's encrypted inside the drive, meaning that no matter what interface is (SATA or USB) user will always see data decrypted.
Got it.
Thanks for the info sir.
PostPosted: April 6th, 2014, 17:29
does anybody have the inic 3608 datasheet?.
PostPosted: June 8th, 2014, 4:19
unknown wrote:
... The weird thing that I recovered the data with SATA PCB. There's no encryption :shock:
Hi
Which PCB did you use, exactly?
I just have the same HDD!
Users browsing this forum: Google [Bot] and 44 guests
