Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 7200.12 cant read disk Please help!
PostPosted: June 9th, 2014, 14:09
My seagate 7200.12 500Gb spins up, but cannot be recognized by any O/S. I have tried Linux partition magic and widows to recover it, but nothing works. Please help me diagnose and fix this problem. My kids baby pics are on there and my laptop crashed that had the backup of them. I really need to get this fixed...
Thanks in advance!
 Post subject: Re: Seagate 7200.12 cant read disk Please help!
PostPosted: June 9th, 2014, 17:51
Thanks for the reply! The drive spins up, and is recognized in the BIOS. However, if I try to let XP boot with the drive attached it will not boot. I used partition magic to try and recover the data, but it doesnt recognize the disk either. I used MHDD to try and read it, but it stops working after I start a scan. I think it gets to like sector 3 million or something and then errors out. All the testing mentioned above was done with a SATA cable directly attached to the mother board.
Seagate Barracuda 7200.12 500Gb.
Firmware: CC33
PostPosted: June 9th, 2014, 18:26
Again, thanks for the reply! Ok, so I started the SCAN off at 10000000 and it went fine up to 50mil or so and then I canceled it. I then started it off a 2.5mil and it went well and then I started getting !!! around 6mill in HDMM and after that it didnt matter what number I started off with, it just gave the that error. Also, I havent played with the TTL stuff. I put a new board on it and that didnt help, so I put the original one back on.
PostPosted: June 10th, 2014, 10:15
Hello Spildit, so I looked at the links in the post above. I had a quick question. Do I only use the GND, TX, and RX side of the USB/TTL module into the corresponding jumper block on the Seagate? Thanks again!
PostPosted: June 10th, 2014, 11:33
Also, will the commands "m0,6,3,,,,,22" format any data, or just simply mark the bad sectors?
PostPosted: June 10th, 2014, 12:20
Spildit wrote:
The command will regenerate the translator (LBA to internal CHS) taking intro consideration the Non-Resident G-List.
In other words, if all goes ok it shouldn't do anything to the user data, instead it will create the translator of the drive that allows for access to sectors using the Logic Block Adressing, trying to fix the problem of partial access by "fixing" the damaged translator susb system.
Awesome, thanks. I have ordered the USB to TTL you recommended from Ebay. I will post again in a few days once I receive the unit and give it a shot. Thanks again!
PostPosted: June 10th, 2014, 13:05
Ok, please be aware that this might not solve the issue and you might still have to send the drive to a data recovery firm / pro to fix the issue with more capable tools, like fixing the translator with the fork method of PC-3000 UDMA or with the Salvation Data Doctor method.
I gotcha, I figured a $7 investment at this point to possibly save $500 is a good idea. If it doesnt work, my plan is to send it to Seagate. Thanks again!
PostPosted: June 12th, 2014, 16:50
Hello I have a hard disk of 2TeraByte ST2000DM001 PCB: 100687658 REV C ,in state BSY.
The terminal output is:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
LED: 000000BD SAddr:0000988E
And do not answer any command. Please I need help to find a solution to this problem.
PostPosted: June 15th, 2014, 20:56
Ok, so I have the usb and connected it all up. I get an -> arrow when I press ctrl-z. Any ideas?
PostPosted: June 15th, 2014, 21:04
Press CTRL+Z again. You should see F3 T> and not just the arrow.
Check the baud rate and the terminal settings as well.
PostPosted: June 15th, 2014, 21:24
So, I got the console to work, and got this back. What does it mean?
ASCII Diag mode
F3 T>m0,6,3,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewr
ite Retries = 0A74
Clear SMART is completed.
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
PostPosted: June 15th, 2014, 22:32
ASCII Diag mode
F3 T>m0,6,3,,,,,22
ite Retries = 0A74
F3 T>
Greetings and good morning !
You should try to scan the drive now with MHDD and check if you can read/verify past the LBAs that you were not able to read before.
PostPosted: June 16th, 2014, 11:07
Tried the scan and got errors this time instead of exclamation points.
PostPosted: June 16th, 2014, 11:50
Also, got this error log:
smartctl 6.0 2012-10-10 r3643 [i686-linux-3.7.9-pmagic] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.12
Device Model: ST3500410AS
Serial Number: 5VM030E7
LU WWN Device Id: 5 000c50 0124898a6
Firmware Version: CC33
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Mon Jun 16 10:37:02 2014 UTC
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/e ... Q/207931en
http://knowledge.seagate.com/articles/e ... Q/213891en
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 592) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 90) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 078 078 006 Pre-fail Always - 6519484
3 Spin_Up_Time 0x0003 099 099 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 090 090 020 Old_age Always - 10441
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 501
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 3
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 431
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 062 062 045 Old_age Always - 38 (Min/Max 37/38)
194 Temperature_Celsius 0x0022 038 040 000 Old_age Always - 38 (0 24 0 0 0)
195 Hardware_ECC_Recovered 0x001a 046 046 000 Old_age Always - 6519484
197 Current_Pending_Sector 0x0012 097 097 000 Old_age Always - 144
198 Offline_Uncorrectable 0x0010 097 097 000 Old_age Offline - 144
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 269603687104517
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 0
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3743057543
SMART Error Log Version: 1
ATA Error Count: 445 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 445 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 08 ff ff ff ef 00 00:35:31.632 READ DMA EXT
c8 00 06 41 08 00 e0 00 00:35:31.631 READ DMA
c8 00 02 3f 08 00 e0 00 00:35:31.602 READ DMA
27 00 00 00 00 00 e0 00 00:35:31.575 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 00:35:31.572 IDENTIFY DEVICE
Error 444 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
25 00 04 ff ff ff ef 00 00:35:28.854 READ DMA EXT
27 00 00 00 00 00 e0 00 00:35:28.827 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 00:35:28.824 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 00:35:28.786 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 00:35:28.708 READ NATIVE MAX ADDRESS EXT
Error 443 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
25 00 02 ff ff ff ef 00 00:35:26.150 READ DMA EXT
27 00 00 00 00 00 e0 00 00:35:26.123 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 00:35:26.120 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 00:35:26.101 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 00:35:26.049 READ NATIVE MAX ADDRESS EXT
Error 442 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
25 00 02 ff ff ff ef 00 00:35:23.444 READ DMA EXT
27 00 00 00 00 00 e0 00 00:35:23.417 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 00:35:23.414 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 00:35:23.395 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 00:35:23.346 READ NATIVE MAX ADDRESS EXT
Error 441 occurred at disk power-on lifetime: 1 hours (0 days + 1 hours)
25 00 02 ff ff ff ef 00 00:35:20.738 READ DMA EXT
27 00 00 00 00 00 e0 00 00:35:20.710 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 00:35:20.707 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 00:35:20.669 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 00:35:20.591 READ NATIVE MAX ADDRESS EXT
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
PostPosted: June 16th, 2014, 11:51
been run.
command.
power-saving mode.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
PostPosted: June 16th, 2014, 12:13
Greetings,
If you can SCAN for the totality of LBAs with MHDD, even with errors that clues me in the direction that the translator problem was fixed and the drive is no longer stuck intro partial access.
Now you have to CLONE the drive to another one and run recovery software like r-studio on the clone.
You should disable relocation to help the cloning process.
PostPosted: June 16th, 2014, 12:14
Ok, I tried to clone it with part magic and got an error that the disk could not be read because it was mounted or something to that effect. I tried to unmount the disk and got an error. Also, do I have to clone it to another disk the same size as this one? Thanks again for the help!
error log.txt [10.47 KiB]
Downloaded 794 times
PostPosted: June 16th, 2014, 12:19
darrell.gray wrote:
So, the disk is recognized in windows XP, but wants me to format it. Any ideas? Also, I got an error log and attached it to this post. Thanks for all the help on this BTW!
The terminal command fixed the translator but the drive might have bad sectors and the MFT might be damaged.
You need to CLONE the drive and run logic recovery software like r-studio, restorer ultimate, getdataback, etc on the drive to recover the files.
PostPosted: June 16th, 2014, 12:29
Thanks for the info! I tried cloning it in part magic and got an error. I cant fully mount or unmount the drive, so its erroring out. Any ideas? Thanks again for the info!
PostPosted: June 16th, 2014, 12:51
If the drive can be scanned with MHDD and if you don't get stuck at a certain LBA with exclamation marks, then all the sectors that can be verifyed/read with MHDD can be cloned as well, and you will only loose the data on the bad blocks.
Do not mount the drive because if the MFT is damaged or the partition tables are damaged it will hang the software when trying to mount the drive, or will not work, and windows will ask to format the drive. Don't do so.
Instead check properly with MHDD and if indee you can read the last LBAs of the drive and you are no longer stuck with exclamation marks, then the TTL command did work and now you have to clone the drive with something like prosoft media tools or the linux dd or ddrescue and then you have to run logic recovery software like r-studio on the clone.
To clone you need an empty drive of the same size or bigger then the drive you are trying to recover the data from.
Users browsing this forum: No registered users and 114 guests
