 Post subject: Seagate ST9500530NS. Listed as as a notebook drive.
PostPosted: June 23rd, 2014, 14:01
My subject line is incomplete. There sere seems to be some question as to whether this drive is a notebook drive because of 2.5 in size or a server Enterprise device.
Can it be used on the desktop running Win 7 by applying HDD Guru tools?
 Post subject: Re: Seagate ST9500530NS. Listed as as a notebook drive.
PostPosted: June 23rd, 2014, 17:32
I can't see why you couldn't use this drive in a desktop machine without making any changes other than the obvious physical ones. The only thing that comes to mind is ERC (Error Recovery Control) which imposes timeout limits on read and write retries. ERC is typically used to ensure that a drive doesn't drop out of a RAID if it remains busy for too long. Desktop drives don't usually enable ERC.
Your other question regarding laptop use would depend on whether your laptop's SATA power connector provides +12V. The ST9500530NS requires both +12V and +5V, whereas most laptop drives need only +5V. AIUI, most (all?) laptops don't provide a +12V supply for the HDD. In fact I recall a thread at Tom's Hardware where a laptop user was unable to get his enterprise drive to work for this reason.
Product Manual - Constellation Serial ATA - ST9500530NS / ST9160511NS:
http://www.seagate.com/staticfiles/supp ... 38694d.pdf
PostPosted: June 23rd, 2014, 19:01
Ok thanks for answering. I was lookign at a used item and may take a chance on it.
Users browsing this forum: No registered users and 40 guests
