 Post subject: Toshiba MK6461GSYN
PostPosted: June 29th, 2014, 23:49
Hi All,
Received this HDD from client - Toshiba MK6461GSYN, doesn't spin up at all. Attached the PCB.
Can anyone tell me where's the diode?
 Post subject: Re: Toshiba MK6461GSYN
PostPosted: June 30th, 2014, 1:46
Check the fuse near L3. If it is open, then check the various supplies for shorts.
PostPosted: July 1st, 2014, 20:58
HI fzabkar,
Thanks so much for help.
Beep when tested
- The little chip with 's' on the left side of L3 beep
- 2 little small black one next to little chip with 's'
without beep
- Little black one on the right side of L3
- 2 orange color one on the left of L3
What's the one with 's'?
PostPosted: July 1st, 2014, 22:54
IMHO this one should "BEEP"
I would say it is a fuse or a resistor, possibly 0 Ohm.
PostPosted: July 2nd, 2014, 19:29
That looks like a capacitor. It's probably the output filter for a switchmode regulator. It should not beep.
PostPosted: July 2nd, 2014, 19:33
That's the fuse.
Littelfuse Surface Mount Fuses, N = 2A, S = 4A:
http://www.farnell.com/datasheets/48294.pdf
PostPosted: July 2nd, 2014, 19:40
That's the fuse.
Its fairly entertaining to read your response about a common fuse to a person who is running a professional data recovery company. :mrgreen:
PostPosted: July 2nd, 2014, 20:00
thatdellguy wrote:
That's the fuse.
It's the "shorted" fuses that amuse me the most.
Users browsing this forum: No registered users and 62 guests
