 Post subject: Question about PC3000 Express and PC3000 UDMA
PostPosted: July 3rd, 2014, 12:05
If I understood it correctly, the difference between PC3000 Express and PC3000 UDMA is Speed and the number of HDDs that each solutions can attend simultaneously. Is there anything else that I should know of ?
Is there any other tool that has the same functionalities and availability of manuals, but without te furstrating Wait time that Acelab is imposing on its customers ?
Thanks for any info
 Post subject: Re: Question about PC3000 Express and PC3000 UDMA
PostPosted: July 3rd, 2014, 12:54
http://www.acelaboratory.com/catalog/
PostPosted: July 3rd, 2014, 13:12
yep, those are the only real differences.
PostPosted: July 4th, 2014, 2:46
and pc3000 express works on 64bit systems I think.
UDMA doesn't.
PostPosted: July 4th, 2014, 2:52
UDMA is now becoming obsolete.
Ace imposes all clients to upgrade to UDMA-E.
As far as I know, support for UDMA will end in 2015 or so.
PostPosted: July 4th, 2014, 17:05
as northwind said, go for pci express,
becouse UDMA has got still 2 years of updates, than will be obsolete, but still working of course.
pci express and udma has got same functionality, only speed is 2x faster and os support to 64 bit.
PostPosted: July 4th, 2014, 17:38
The main difference:
EŃ…press - 4-channel PCI-E and 4-port SATA (or 2 SATA + 2 PATA)
Tasks for each port is not dependent.
UDMA-E - 1-chennel. but 2-port SATA (or 1 SATA + 1 PATA)
dependent tasks.
PostPosted: July 5th, 2014, 16:03
UDMA suport is schedule to end in January 2016.
But I suspect that with MRT competition it may end sooner.
Right now prices on the Express are high, hopefully the will drop a little in the future.
PostPosted: July 6th, 2014, 7:47
-BR-,
Hardly the price drops.
Actually Excpress replaces 2-4 Udma-E.
So buy it more profitable than a few udma-E
PostPosted: July 6th, 2014, 14:02
Tomset wrote:
-BR-,
As my point of view
I never like to Keep all the eggs in ONE BASKET
but 2 baskets MAYBE
PostPosted: July 6th, 2014, 14:31
einstein9,
To each his own.
Saves space, do not need a lot of computers.
Tasks for each channel are independent.
If one hangs, others work.
In contrast to the PC3k-PCI, where hung all tasks.
DE runs and regular discs connected not only with the controller.
Simultaneity can run many tasks as there are free ports on the PC.
For one master Express is very convenient.
PostPosted: July 6th, 2014, 20:15
UDMA doesn't.
yes it works under 64bit environment.
Data Recovery Pakistan
