 Post subject: Zephir usb 2060-771737-000
PostPosted: June 25th, 2013, 13:06
zephir usb board 2060-771737-000 REVA not compatible with zephir sata 2060-771820-000 REVA ( do not power on motor )
and if somebody solved this and could report - much appreciated also PM.
 Post subject: Re: Zephir usb 2060-771737-000
PostPosted: June 25th, 2013, 14:19
in your case here, you killed the pcb (i think)
even with new rom soldering it will not work right? :iknow:
PostPosted: June 25th, 2013, 16:12
viewtopic.php?f=1&t=23949&p=161468
viewtopic.php?f=1&t=23305&p=164116
PostPosted: July 14th, 2014, 0:03
Banned User
It is better you can use same board number PCB to be the donor PCB. Also you need to move your original PCB's BIOS to the replacement PCB.
Users browsing this forum: No registered users and 172 guests
