 Post subject: WD WD5000AAKS 65YGA0 problem
PostPosted: July 15th, 2014, 8:53
I have a WD5000AAKS 65YGA0 (yellow) https://dl.dropboxusercontent.com/u/11301095/IMG_20140714_123336.jpg
The symptoms:
- disk spin up - but not always;
- If it spins the BIOS detects;
- But neither windows nor freebsd nor DOS no longer see;
- If I put it to USB case, the Windows 7 recognizes as a service sometimes , but the disk controller can no longer see it.
It was bootable disk but I have not use for system.
Could anyone has any idea? (I need the data only)
 Post subject: Re: WD WD5000AAKS 65YGA0 problem
PostPosted: July 15th, 2014, 20:10
For starters, search keyword "rubber eraser" in the forum and read a bit.
PostPosted: July 16th, 2014, 3:47
Maybe you are on true, maybe corrosion in spinning contacts, very probably
PostPosted: July 16th, 2014, 4:21
See http://malthus.zapto.org/viewtopic.php?t=649
PostPosted: July 16th, 2014, 5:35
Maybe you are on true, maybe corrosion in spinning contacts or the preamp and VCM contacts, very probably.
Can you clean it, and report us?
PostPosted: July 17th, 2014, 4:21
Thanks the ideas but I have not time (and safety place - I have 3 kids... :) ) yet. But at the weekend I will resurrect the disk! (I hope!! :wink: )
PostPosted: July 17th, 2014, 4:36
If you have no time you can contatc with a Pro;
In Hungary you have N.C., pepe, and so on
memberlist.php?mode=viewprofile&u=7771
memberlist.php?mode=viewprofile&u=119
I think they will be nice price for that work
PostPosted: July 18th, 2014, 5:32
THANKS YOUR HELP!!! I am really really grateful!
The "rubber eraser" was success.
https://dl.dropboxusercontent.com/u/11301095/IMG_20140717_184240.jpg It was the PCB after the opening. It was cleared, and now it is working. I move my data to another disk, and I am HAPPY now!!!! :)
Thanks again!!
PostPosted: July 18th, 2014, 10:05
great news ;) I love it when a plan comes together!
Users browsing this forum: Google [Bot] and 63 guests
