Rom needed , any help
January 22nd, 2014, 7:02
View module 90 information
Total heads............................. : 4
Used heads.............................. : 4
Mdl 47 version.......................... : GJ.40192
ROM Version version..................... : 00100019 (10.19)
Mdl 11 Version.......................... : 00100019 (10.19)
For WD5000BMVW-11AMCS0
Thank you.
Re: Rom needed , any help
January 22nd, 2014, 10:05
Here you go....
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1098
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 10.19A
>ROM generation.......................... : 10.19A
>Link table version...................... : 02.17.
>Consolidated ROM version................ : 00100019
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 00100019
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
ROM.rar
(241.24 KiB) Downloaded 377 times
January 22nd, 2014, 10:15
Thank you! :beer:
July 26th, 2014, 11:56
hello, if possible to have the modules for this Zephyr? Thanks in advanced
