 Post subject: Unfamiliar hard drive failure sound
PostPosted: July 18th, 2014, 3:57
Hello all, Just registered!
Ive been toying around with hard drives lately, mainly tinkering with drives I dont need.
I found a 1tb portable Western Digital Hard drive.(WD10TMVW) It is making quite a peculiar beeping sound.
Ive uploaded the sound it makes...
http://vocaroo.com/i/s1NULxBtrU7r
I opened it up and set the head back to its parking position, as it was on the platter.
The same peculiar noise persists.
Any ideas what the noise could be trying to tell me?
Any help would be valued!
Thanks.
 Post subject: Re: Unfamiliar hard drive failure sound
PostPosted: July 18th, 2014, 4:38
The noise you recorded is caused by stiction (heads stuck to platters).
If you say you parked heads back to ramp and same behavior insists, then heads were stuck to platters again (for some reason), or you didn't unstuck heads properly. There is a small chance that motor is the culprit, but it is 0,1% for this drive.
PostPosted: July 18th, 2014, 8:19
I'm sure I parked the heads. Perhaps they aren't parked precisely?
I've opened it up again and the heads are parked. Will an uploaded image help?
PostPosted: July 18th, 2014, 11:16
I think iit sounds like stiction too.
Send pic, but remember is you open the drive without clean beanch you put in risk data.
PostPosted: July 18th, 2014, 12:28
Did you park the heads off the platters and on the load/unload ramp? Can you rotate the motor afterwards by hand?
Users browsing this forum: No registered users and 127 guests
