 Post subject: My drive is not recognized by HDD LLFT!!!
PostPosted: July 22nd, 2014, 8:21
I own a WD 750GB drive as a backup drive for my data. Recently the MBR of the drive and partition table were messed up and my drive is not recognized by the OS (Win & Ultimate x64) anymore. I'm using HDD LLFT to reformat the drive as I have already backed up all my files and folders to try to restore the drive to its working condition, if that helps.
HDD LLFT reports this:
"Current date and time: 7/22/2014 1:48:18 PM
HDD Low Level Format Tool 4.40; http://hddguru.com
Device details for [1] WDC WD75 01AALS-00E3A 05.0 [750.15 GB] (1465149168 512-byte sectors)
Details are unavailable: Internal error.
Please post this problem on http://forum.hddguru.com"
According to this log, may it be that my HDD is defective (hardware issue)? Should I consider to RMA this drive if the warning is smth. serious?
Please, I need some opinion/advice on this issue, and how to fix it.
Thank you
 Post subject: Re: My drive is not recognized by HDD LLFT!!!
PostPosted: July 22nd, 2014, 18:43
If Western Digital's Data LifeGuard (DOS version) utility fails your drive, then I would replace it.
PostPosted: July 22nd, 2014, 18:45
You are running the program as an administrator right??? (I would assume it only runs that way)
If not windows could be blocking your from wiping the partition table.
PostPosted: July 22nd, 2014, 18:46
Try a program like Active KillDisk. If you can run a zero fill pass, the drive is good. If it fails, RMA it.
PostPosted: July 24th, 2014, 5:06
+ data-medics.
Active KillDisk is a good way to know if drive is badly
Users browsing this forum: No registered users and 93 guests
