 Post subject: Fixing RBBLIST & P-list.
PostPosted: July 28th, 2014, 8:26
The drive data area is inaccessible.
WD800JD-60LSA5
Found bad FW
PRIMARY DEFECT LIST (31)
RBBLIST (32)
G-LIST (34)
P-LIST is OK. But data inaccessible. Full of !!!!!!!!!!!!
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Fixing RBBLIST & P-list.
PostPosted: July 28th, 2014, 8:27
Have translation issue.
PostPosted: July 28th, 2014, 8:31
Did translator regeneration... but failed
__________
THANK YOU
SHAHI
PostPosted: July 28th, 2014, 8:35
What is the error produced?
Mods and tracks are ok? May have bad sectors in the translator module space allocation.
PostPosted: July 28th, 2014, 14:33
CRC Error on SD Tools on both Primary & Secondary.
Translator Regen Fails.
Can't reallocate modules (Due to Limited Feature on SD)
Spildit wrote:
Damaged p-list ?
Did you try smart hot swap ?
P-list ok (Mod#33)
Damaged Primary Defects list, Glist and RBBlist.
Checked a good/working HDD, on Good HDD, the Glist is also bad.
No, I didn't try SMART Hot-Swap.
As, the SA is accessible directly, then do you think SMART HOT SWAP might work?
__________
THANK YOU
SHAHI
PostPosted: July 29th, 2014, 0:56
Whenever I try to write something on MOD 31, HDD gets POWER RESET. Write fails.
Do You Think, Because of HEAD FAILURE might this happen?
Recently I had an CASE ATA MODULE(MOD#11) Failure. But rewrite fails. According to the history of the HDD, the drive was fallen to the floor. But while I received the HDD would come to READY, No Clicking Noise. SA Area was accessible, only problem was ATA module, but write failed. The case was returned as it was to delivery within 24 hours.
__________
THANK YOU
SHAHI
PostPosted: July 29th, 2014, 3:06
I could do this with MHDD scripts. It should also be possible to do it with SD tools, even if there is no single-click solution.
Just find a non-essential MOD that is large enough and write the contents of your damaged MOD to it. Then edit the directory entries in MOD 01, ie change the MOD IDs and sizes.
PostPosted: July 29th, 2014, 5:09
31 is Translator. Easily fixable by manually relocating mod to unused service track.
PostPosted: July 29th, 2014, 5:41
Customer denied to give quoted charge. Case Close.
I'll check the reallocation later by SD tool to another not-important HDD.
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 413 guests
