 Post subject: WD HAWK
PostPosted: July 30th, 2014, 16:04
Hi to all! :mrgreen:
wd is bad heads?
Is original 6 heads (0,1,2,3,4,5) is clicking 3x and off.
Is head 1 only.
look.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 64
Zone allocation table................... : Ok
SA SPT.................................. : 720
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 02.1KC
ROM generation.......................... : 02.1KC
Link table version...................... : 01.23.
Consolidated ROM version................ : 0002001K
ROM Modules:
Heads number............................ : 6
Heads number in use..................... : 1
Switched off heads...................... : Yes
Heads map............................... : 1
ROM Firmware version.................... : 021KC
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok (Copy 0)
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
HDD resources backup
Reading modules
Into folder............................. : <HDD Profile>\Data\SABackup\Modules\
Reading method.......................... : Selected copies
Module : 01 Copy 0...................... : Ok
Module : 01 Copy 1...................... : Ok
Module : 25 Copy 0...................... : Ok
Module : 25 Copy 1...................... : Ok
Module : 17 Copy 0...................... : Ok
Module : 17 Copy 1...................... : Ok
Module : 28 Copy 0...................... : Ok
Module : 28 Copy 1...................... : Ok
Module : 34 Copy 0...................... : Ok
Module : 34 Copy 1...................... : Ok
Module : 2F Copy 0...................... : Ok
Module : 2F Copy 1...................... : Ok
Module : 36 Copy 0...................... : Ok
Module : 36 Copy 1...................... : Ok
Module : 35 Copy 0...................... : Ok
Module : 35 Copy 1...................... : Ok
Module : 02 Copy 0...................... : Ok
Module : 02 Copy 1...................... : Ok
Module : 33 Copy 0...................... : Ok
Module : 33 Copy 1...................... : Ok
Module : 26 Copy 0...................... : Ok
Module : 26 Copy 1...................... : Ok
Module : 1C Copy 0...................... : Ok
Module : 1C Copy 1...................... : Ok
Module : 2A Copy 0...................... : Ok
Module : 2A Copy 1...................... : Ok
Module : 31 Copy 0...................... : Ok
Module : 31 Copy 1...................... : Ok
Module : 1B Copy 0...................... : Ok
Module : 1B Copy 1...................... : Ok
Module : 19 Copy 0...................... : Ok
Module : 19 Copy 1...................... : Ok
Module : 15 Copy 0...................... : Ok
Module : 15 Copy 1...................... : Ok
Module : 50 Copy 0...................... : Ok
Module : 50 Copy 1...................... : Ok
Module : 2D Copy 0...................... : Module reading error: Physical read error C/H/S: -8/0/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 2D Copy 1...................... : Module reading error: Physical read error C/H/S: -40/0/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 22 Copy 0...................... : Module reading error: Physical read error C/H/S: -8/0/270 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 22 Copy 1...................... : Module reading error: Physical read error C/H/S: -40/0/270 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 1E Copy 0...................... : Ok
Module : 1E Copy 1...................... : Ok
Module : 41 Copy 0...................... : Ok
Module : 41 Copy 1...................... : Ok
Module : 06 Copy 0...................... : Ok
Module : 06 Copy 1...................... : Ok
Module : 29 Copy 0...................... : Ok
Module : 29 Copy 1...................... : Ok
Module : 51 Copy 0...................... : Ok
Module : 51 Copy 1...................... : Ok
Module : 2E Copy 0...................... : Ok
Module : 2E Copy 1...................... : Ok
Module : 24 Copy 0...................... : Ok
Module : 24 Copy 1...................... : Ok
Module : 32 Copy 0...................... : Ok
Module : 32 Copy 1...................... : Ok
Module : 4C Copy 0...................... : Ok
Module : 4C Copy 1...................... : Ok
Module : 04 Copy 0...................... : Ok
Module : 04 Copy 1...................... : Ok
Module : 4A Copy 0...................... : Ok
Module : 4A Copy 1...................... : Ok
Module : 52 Copy 0...................... : Ok
Module : 52 Copy 1...................... : Ok
Module : 11 Copy 0...................... : Ok
Module : 11 Copy 1...................... : Ok
Module : 23 Copy 0...................... : Ok
Module : 23 Copy 1...................... : Ok
Module : 43 Copy 0...................... : Ok
Module : 43 Copy 1...................... : Ok
Module : 40 Copy 0...................... : Ok
Module : 40 Copy 1...................... : Ok
Module : 07 Copy 0...................... : Ok
Module : 07 Copy 1...................... : Ok
Module : 0C Copy 0...................... : Ok
Module : 0C Copy 1...................... : Ok
Module : 49 Copy 0...................... : Ok
Module : 49 Copy 1...................... : Ok
Module : 38 Copy 0...................... : Ok
Module : 38 Copy 1...................... : Ok
Module : 21 Copy 0...................... : Module reading error: Physical read error C/H/S: -11/0/262 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 21 Copy 1...................... : Module reading error: Physical read error C/H/S: -43/0/262 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : 42 Copy 0...................... : Ok
Module : 42 Copy 1...................... : Ok
Module : 39 Copy 0...................... : Ok
Module : 39 Copy 1...................... : Ok
Module : 05 Copy 0...................... : Ok
Module : 05 Copy 1...................... : Ok
Module : 53 Copy 0...................... : Ok
Module : 53 Copy 1...................... : Ok
Module : 37 Copy 0...................... : Ok
Module : 37 Copy 1...................... : Ok
Module : C4 Copy 0...................... : Ok
Module : C4 Copy 1...................... : Ok
Module : C5 Copy 0...................... : Ok
Module : C5 Copy 1...................... : Ok
Module : CC Copy 0...................... : Ok
Module : CC Copy 1...................... : Ok
Module : CA Copy 0...................... : Ok
Module : CA Copy 1...................... : Ok
Module : CB Copy 0...................... : Ok
Module : CB Copy 1...................... : Ok
Module : CD Copy 0...................... : Ok
Module : CD Copy 1...................... : Ok
Module : CF Copy 0...................... : Ok
Module : CF Copy 1...................... : Ok
Module : CE Copy 0...................... : Ok
Module : CE Copy 1...................... : Ok
Module : 91 Copy 0...................... : Ok
Module : 91 Copy 1...................... : Ok
Module : 92 Copy 0...................... : Ok
Module : 92 Copy 1...................... : Ok
Module : 93 Copy 0...................... : Ok
Module : 93 Copy 1...................... : Ok
Module : C1 Copy 0...................... : Ok
Module : C1 Copy 1...................... : Ok
Module : C2 Copy 0...................... : Ok
Module : C2 Copy 1...................... : Ok
Module : C7 Copy 0...................... : Ok
Module : C7 Copy 1...................... : Ok
Module : 9E Copy 0...................... : Ok
Module : 9E Copy 1...................... : Ok
Module : B1 Copy 0...................... : Ok
Module : B1 Copy 1...................... : Ok
Module : E0 Copy 0...................... : Ok
Module : E0 Copy 1...................... : Ok
Module : E8 Copy 0...................... : Ok
Module : E8 Copy 1...................... : Ok
Module : FE Copy 0...................... : Ok
Module : FE Copy 1...................... : Ok
Module : D5 Copy 0...................... : Ok
Module : D5 Copy 1...................... : Ok
Module : DA Copy 0...................... : Ok
Module : DA Copy 1...................... : Ok
Module : DB Copy 0...................... : Ok
Module : DB Copy 1...................... : Ok
Module : DF Copy 0...................... : Ok
Module : DF Copy 1...................... : Ok
Module : DD Copy 0...................... : Ok
Module : DD Copy 1...................... : Ok
Module : D6 Copy 0...................... : Ok
Module : D6 Copy 1...................... : Ok
Module : D7 Copy 0...................... : Ok
Module : D7 Copy 1...................... : Ok
Module : D2 Copy 0...................... : Ok
Module : D2 Copy 1...................... : Ok
Module : BB Copy 0...................... : Ok
Module : BB Copy 1...................... : Ok
Module : D9 Copy 0...................... : Ok
Module : D9 Copy 1...................... : Ok
Module : D4 Copy 0...................... : Ok
Module : D4 Copy 1...................... : Ok
Module : DC Copy 0...................... : Ok
Module : DC Copy 1...................... : Ok
Module : D0 Copy 0...................... : Ok
Module : D0 Copy 1...................... : Ok
Module : D3 Copy 0...................... : Ok
Module : D3 Copy 1...................... : Ok
Module : BA Copy 0...................... : Ok
Module : BA Copy 1...................... : Ok
Module : B9 Copy 0...................... : Ok
Module : B9 Copy 1...................... : Ok
Module : BC Copy 0...................... : Ok
Module : BC Copy 1...................... : Ok
Module : FD Copy 0...................... : Ok
Module : FD Copy 1...................... : Ok
Module : FB Copy 0...................... : Ok
Module : FB Copy 1...................... : Ok
Module : E6 Copy 0...................... : Ok
Module : E6 Copy 1...................... : Ok
Module : E7 Copy 0...................... : Ok
Module : E7 Copy 1...................... : Ok
Module : BE Copy 0...................... : Ok
Module : BE Copy 1...................... : Ok
Module : B8 Copy 0...................... : Ok
Module : B8 Copy 1...................... : Ok
Module : BF Copy 0...................... : Ok
Module : BF Copy 1...................... : Ok
Module : FC Copy 0...................... : Ok
Module : FC Copy 1...................... : Ok
Module : EE Copy 0...................... : Ok
Module : EE Copy 1...................... : Ok
Module : E1 Copy 0...................... : Ok
Module : E1 Copy 1...................... : No copy exists
Module : E2 Copy 0...................... : Ok
Module : E2 Copy 1...................... : No copy exists
Module : E3 Copy 0...................... : Ok
Module : E3 Copy 1...................... : No copy exists
Module : E4 Copy 0...................... : Ok
Module : E4 Copy 1...................... : No copy exists
Module : E5 Copy 0...................... : Ok
Module : E5 Copy 1...................... : No copy exists
Module : E9 Copy 0...................... : Ok
Module : E9 Copy 1...................... : No copy exists
Module : EA Copy 0...................... : Ok
Module : EA Copy 1...................... : No copy exists
Module : EB Copy 0...................... : Module reading error: Physical read error C/H/S: -40/0/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
Module : EB Copy 1...................... : No copy exists
Module : EC Copy 0...................... : Ok
Module : EC Copy 1...................... : No copy exists
Module : ED Copy 0...................... : Ok
Module : ED Copy 1...................... : No copy exists
Backup process completed
21,22 => SMART
2D => debug log
EB => Faltory self test head 3
Нет ничего невозможного
 Post subject: Re: WD HAWK
PostPosted: July 31st, 2014, 8:42
any comment? :shock:
PostPosted: July 31st, 2014, 8:44
Maybe wrong, but quick guess would be ROM was modified OR PCB may not be native.
PostPosted: July 31st, 2014, 9:46
yes pcbs native!
I modified the rom :mrgreen:
Thanks!!
PostPosted: August 5th, 2014, 8:12
then why you ask:
wd is bad heads?
PostPosted: August 5th, 2014, 9:12
@Sempre: Did you receive the drive as previously opened? If yes, there is a possibility there are alignment issues.
Users browsing this forum: No registered users and 255 guests
