 Post subject: WD My Passport Ultra Problem plz Help
PostPosted: August 1st, 2014, 14:16
It's not showing at my computer like this pic
but in try see the pic
device manager
Disk management
have you face this problem
thanks to all
 Post subject: Re: WD My Passport Ultra Problem plz Help
PostPosted: August 1st, 2014, 16:54
Hello alwasatgate,
first try to connect drive to another computer and try.
If this Will not work, then without knowledge Will be hard to do anything.
If data are valuable for you, contact pro data recovery service.
PostPosted: August 2nd, 2014, 0:37
Hello alwasatgate,
i change the computer i do many thinks but still i can't solve this problem ...
i can go to pro data recovery service but ... let's think first coz i face many wd with this problem
no one face this problem with wd usb3 ext Hdd ?!
thanks
PostPosted: August 2nd, 2014, 2:48
Hello alwasatgate,,
when you connect drive to computer are there any strange sounds? Did drive spin up?
Could you post drive model
PostPosted: August 12th, 2014, 18:17
Hi man and thanks for your help
i have more than one wd ext hdd usb3
normal sound normal work driver ok but can't see it at my computer or device manager
i will try to record video
thanks
PostPosted: August 13th, 2014, 1:09
Hello alwasatgate,
it could be two things. First firmware problem or second USB2SATA adapter(integrated on PCB)
Do you have hot airgun and soldering iron and torx screw driver.
And you will need to put drive out of enclosure and post PCB number or better picture of it
Users browsing this forum: No registered users and 53 guests
