 Post subject: Head Replacement on SAS disks
PostPosted: September 8th, 2014, 5:38
I have a 2.5'' SAS disk with broken heads. Is it the head replacement procedure similar to SATA disks?
Are the Hard Drive Match Criteria for Head Stack Assembly replacement the same as for SATA disks?
The disk is a Toshiba/Fujitsu MBD2147RC.
Your help will be appreciated.
 Post subject: Re: Head Replacement on SAS disks
PostPosted: September 8th, 2014, 8:13
hi Miss Di!
the procedure is the same.
about Match Criteria maybe any body can help you.
PostPosted: September 8th, 2014, 11:22
Sometimes the procedure is mechanically quite different from most other hard drives, depending upon the model -- especially those with 2.5" platters in a 3.5" enclosure.
http://www.datasaversllc.com
Users browsing this forum: Google [Bot] and 101 guests
