 Post subject: how to test pc 3000 express? bsod
PostPosted: August 28th, 2014, 12:47
BSOD after run pc 3000. Checked system, clean, PSU/MB ok, CPU less than 37 degree, rum memory test 17 times, no error, changed harddrive, same. Now bsod when open pc 3000 express, must reinstall everything. How to test pc 3000 card?
 Post subject: Re: how to test pc 3000 express? bsod
PostPosted: October 2nd, 2014, 20:24
could be the onboard memory one of them has gone down
did you do a clean install of windows and not have no programs running at the start only the pc3000
remove any anti virus
also you run memory test what program did you use as there diffrent ones out there that only support certain rams which will give you a fake pass
PostPosted: October 3rd, 2014, 2:29
I would do a test of the system and computer without the card installed...first.
http://www.rescue-it.se
Users browsing this forum: Google [Bot] and 74 guests
