HTS725032A9A364 - Bad Heads ?
August 26th, 2014, 18:19
This drive had a burnt out board. Looked like liquid had been spilled on the laptop. Installed new board and NV-RAM swap. Drive comes DRD without clicking. I can read/write NV-RAM okay. Switched off heads in RAM. Any interaction with the drive causes it to either go BSY (and stay BSY) or ERR UNC. Is this bad heads?
Re: HTS725032A9A364 - Bad Heads ?
August 27th, 2014, 3:59
Listen very carefully to the drive when powering up, do you near the heads come off the ramp and sweep the platters?
Compare the sound to a good drive if you're unsure.
August 27th, 2014, 13:17
The heads do come off the ramp. However it does make a different sound to a good drive. With the good drive it sounds like to heads come off the ramp, sweep the platters and gives a short electronic buzz/vibration when it reads data. The bad drive comes off the ramp and sweeps, but doesn't sound like its reading data.
August 27th, 2014, 14:40
Further to this I just opened the drive in the cleanroom. The heads do pass over the platters briefly when spinning up.
August 28th, 2014, 10:09
Ok. Is the new ROM version compatible with the original NVRAM version?
August 28th, 2014, 20:41
Looks to me like they are??
ROM.txt
(688.2 KiB) Downloaded 590 times
NV-RAM.txt
(2.58 KiB) Downloaded 589 times
August 29th, 2014, 2:58
Looks like it, and "VLG1XRBCL" is the serial number of the drive?
August 29th, 2014, 14:32
pcimage wrote:Looks like it, and "VLG1XRBCL" is the serial number of the drive?
Hmm. No its not. It is a donor board with the chip swapped. The full serial number of this drive is 091127PC6J00VQG10JWA, so I am assuming it just details the last few digits.
August 29th, 2014, 16:13
Then the PCB is not original, or you have moved the wrong chip.
August 29th, 2014, 16:28
Here is the chip I moved.
August 29th, 2014, 16:31
Wrong one! That's the ROM.
There should be a smaller (NVRAM) one, U6 from memory (at home now).
Won't hurt to move both, so move the NVRAM and you should be good to go!
August 29th, 2014, 16:48
Thanks...
